Metro 16v Gti Into Mini
Posted 29 January 2011 - 12:18 AM
will this sub frame and running gear bolt straight into my mini as i'm fed up with unreliable
A series
Posted 29 January 2011 - 12:19 AM
Posted 29 January 2011 - 12:26 AM
I was in the same position as you about 4 years back, I was offered a metro GTI and was considering doing an engine conversion. But you need to buy the aftermaket subframe, or build one yourself. Its also a similar amount of work to putting in a honda or a vauxhall, so in the end I didnt even collect the Metro, I sold it onto someone else and made a profit and they went and collected it!
for all the work involved, I would recommend a small block vauxhall instead (my personal opinion)
Posted 29 January 2011 - 12:32 AM
Posted 29 January 2011 - 12:49 AM
Posted 29 January 2011 - 03:17 PM
Straight up answer, nomight have got a chance of getting low mileage metro 16v GTI
A series
You can use a metro subframe and running gear, but will need an extended front. Alternatively you can, as E.L.M.O says you can buy an aftermarket subframe and fit it all under a standard nose. Both of these conversions are far more involved and require a lot more effort than making a reliable A series.
The K series is much lighter than the Honda or vauxhall engines, which was why i chose it
The metro gti engine is also the same engine as fitted to any other 1.4 rover with a distributor cap.
All the other parts can be found on various other cheaper rovers too. The GTi badge has the same effect as a cooper tag, on the prices
Edited by charie t, 29 January 2011 - 03:23 PM.
Posted 29 January 2011 - 07:50 PM
with regards to the unreliable A series i was commenting on my experience over the past 2 years with my car.(some people seem a bit touchy on here!!!) after buying the mini from a friend who spend thousands on a morspeed engine and gear box
its had 2 rolling road sessions with all new ignition parts and still is not really running spot on.
so implying that it is caused by lack of maintaince is nonsence
Posted 29 January 2011 - 08:39 PM
injection, 5 gears blah blah blah 90bhp all day long.
blow it up, 50 quid you have another engine.
Posted 29 January 2011 - 10:02 PM
Posted 30 January 2011 - 03:43 PM
