Best Mods To Increase Acceleration On 1275 Engine
Posted 29 January 2011 - 01:59 PM
jay
Posted 29 January 2011 - 02:02 PM
The usual stuff will help though:
Big bore exhaust, big carb, flowed head, cam change. Then you could perhaps look into reducing the losses from your powertrain.
Posted 29 January 2011 - 02:05 PM
Posted 29 January 2011 - 02:27 PM
Posted 29 January 2011 - 02:45 PM
Posted 29 January 2011 - 04:20 PM
If you want to go any further, then the costs and the amount of work involved soon starts to escalate. The next stages are mods such as roller tip rockers, modified heads, uprated cams, lightened fly wheels, lightened & balanced cranks etc. All of which will are very unwise mods if your engine is either tired or high milage, like so many mini engines are these days. If you are considering these sorts of mods then you probably need to budget for an engine and gearbox rebuild as well, otherwise the mods will wreck your engine in no time! Also if you significantly improve the performance of any car, you will also need to invest time and money uprating the brakes, tyres and suspension etc in order to cope with the additional power. Otherwise the extra performance will be both dangerous and unusable.
Edited by AVV IT, 29 January 2011 - 04:21 PM.
Posted 29 January 2011 - 06:27 PM
Posted 29 January 2011 - 06:47 PM
Posted 29 January 2011 - 07:44 PM
Posted 29 January 2011 - 08:07 PM
Posted 29 January 2011 - 08:17 PM
Posted 29 January 2011 - 08:42 PM
Posted 29 January 2011 - 09:02 PM
I would mainly like to increase the acceleration more than top speed
Easy one
Push the pedal harder
Other than that, I would recommend
A full service and thorough maintenance program is the first place to start (there is no point trying to modify something that's not performing to it's optimum as standard in the first place) then also strip out any unnecessary weight from the car. If you want to spend some cash then fit a well developed stage 1 kit (high flow air filter, richer carb needle, flowed inlet & exhaust manifold, & performance exhaust system - avoid large bore systems & go for standard bore single exit for best performance gains on a standard engine). These sort of mods & work involve you getting a modest but noticeable performance increase, for a relatively small amount of work and outlay.
Posted 29 January 2011 - 11:25 PM
Posted 30 January 2011 - 01:04 AM
