engine removal
6 replies to this topic
#1 THedooBZ
THedooBZ
  • 887 posts
Posted 28 December 2005 - 03:30 PM
hi all,
basically iv got my engine nearlly out the only thing left to do is disconnect the clutch slave cylinder do you have to rebleed the system or is there any other way??
#2 The Matt
The Matt
  • 17,229 posts
  • Name: Matt
Posted 28 December 2005 - 03:33 PM
If there is enough flex in the pipe, could you unbolt it from the transfer case and move it out of the way?
If you can, try to tie a cable tie or similar around the cylinder so the end doesn't 'pop out'.
#3 THedooBZ
THedooBZ
  • 887 posts
Posted 28 December 2005 - 03:37 PM
yeah there is enough room to move it but im worried that if i diconnect it , it will shoot hydraulic fluid everywhere
#4 The Matt
The Matt
  • 17,229 posts
  • Name: Matt
Posted 28 December 2005 - 03:50 PM
Nah, if you leave the hose connected and tie it so the cylinder can't pop out it should be fine. No loss of fluid and no bleeding bleeding!
#5 THedooBZ
THedooBZ
  • 887 posts
Posted 28 December 2005 - 03:52 PM
ill give that a go now then ,cheers for the advice. :)
#6 The Matt
The Matt
  • 17,229 posts
  • Name: Matt
Posted 28 December 2005 - 03:53 PM
:grin: no probs, hope it works OK :wink:
#7 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 28 December 2005 - 06:56 PM
Just dont push the pedal !!
