Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model: austin mini
Year: 1989
Description of problem (please be as in depth as possible): Oil leak
I know minis leak oil, but mine has been leaking a quart or so every 3 weeks. I finally jacked it up and cleaned it underneath and let it idle for about 10 minutes. Here are pictures of the result. It's leaking from two spots that I can find find, both on the drivers side (german spec mini, left-hand drive). Hopefully you can make it out in the pictures.
What are these two areas, and what is needed to fix the leaks?
