Car Jerking
11 replies to this topic
#1 westpark15
westpark15
  • 133 posts
  • Local Club: mini drivers club
Posted 31 January 2011 - 11:06 PM
Neon
1990/91
When I put my foot down the car jerks sometimes but also struggle to move off at times so I have to pull the choke out wondering if anyone could suggest any ideas to help ?
Any non-standard parts that might be involved with the problem?
I have a stage one kit on
Ported and polished head
Thanks Nigel
#2 mattdc2r
mattdc2r
  • 1,296 posts
  • Local Club: Not yet!
Posted 31 January 2011 - 11:11 PM
This all the time or just when cold?
Was the car set up properly on rolling road after stage 1 kit fitted? All fuel filter's in good condition? Air filter not blocked?
Few easy things to start Off with :)
#3 minidream94
minidream94
  • 1,233 posts
Posted 31 January 2011 - 11:12 PM
could be ht leads?
#4 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 31 January 2011 - 11:18 PM
Sounds like the fueling needs to be setup if your needing choke when pulling away
#5 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 31 January 2011 - 11:22 PM
Open your bonnet and grab your engine (when cold!) and try rocking it back n forth, apart from your engine not running properly it could be your mounts aswell
#6 Kam
Kam
  • 4,140 posts
Posted 31 January 2011 - 11:25 PM
As above, there is quite a few basic things you can check with the car stationery
Make sure your dashpot (big black screw at the top of the carb) is topped up aswell
#7 westpark15
westpark15
  • 133 posts
Posted 01 February 2011 - 05:43 PM
how can i change the oil out of the dashpot to put new in ?
and its quite alote of the time if i pull my choke out runs fine
tomorow im getting my electronic dizzy fitted and going to look at the mixtures also
any other ideas?
thanks nigel
#8 Cooperman
  • 23,309 posts
Posted 01 February 2011 - 06:17 PM
any other ideas?
thanks nigel
You just top up the dashpot with 3-in-1 oil. It should be about 1/2" from the top when filled.
If it only runs properly with choke out it's either too lean or there is an air leak in the inlet system after the carb.
#9 westpark15
westpark15
  • 133 posts
Posted 01 February 2011 - 07:52 PM
Any other solutions ?
#10 caz000666
caz000666
  • 26 posts
  • Local Club: A Series Magpies
Posted 01 February 2011 - 07:58 PM
sounds a lot like my 998 mini 30, mines down to a weak spark, have you checked over the usual elec stuff, or it could be down to an incorrect fuel air mix.... use gunson color tune to check the mix
use an inline spark checker to see how poor your spark is (there are more unsafe ways such as using VDE pliers to hold a removed sparkplug against the side of the block) BUT THIS IS NOT ADVISED!!
#11 Kam
Kam
  • 4,140 posts
Posted 01 February 2011 - 08:13 PM
Have you tried the above ones first? People are trying to give you the common solutions based on what your describing
If you haven't got any 3in1 oil lying about then just use normal engine that you use
#12 westpark15
westpark15
  • 133 posts
Posted 02 February 2011 - 06:22 PM
seems to be fixed since its been correctly ajusted :thumbsup: and timed
