I have a pair of metric verniers but no dial gauge, and I already know that Inlet valves should be 30.93mm and Exhaust 24.4mm.
Many thanks!
Edited by Bradfirj9, 01 February 2011 - 04:28 PM.
Posted 01 February 2011 - 04:27 PM
Posted 01 February 2011 - 04:48 PM
Posted 01 February 2011 - 04:54 PM
Posted 14 March 2011 - 08:40 PM
Can't remember the exact as-new chamber capacity, but it's in the region of 26 cc. However, the critical thing is how much it has been skimmed as the oil feed hole can break through the head face. Check this with a vernier gauge by measuring the thickness of the head and subtracting from it the depth of the oil hole. You need about 0.080" remaining to allow a bit more skimming if required.
You will need to do a compression ratio measure/calculate before assembling so just check that oil hole depth and inspect for any cracking between valve seats.
Edited by Bluecray, 14 March 2011 - 08:41 PM.
Posted 14 March 2011 - 10:24 PM
Posted 14 March 2011 - 10:27 PM
The original head width (thickness) is 2.75 inches . I have a 12g295 with .120" skimmed off and still a fair amount of metal left before breaking into the oil passage. Heads obviousley varied in this area.
Posted 14 March 2011 - 10:34 PM
Yes but not by much, .35mm which is around .014", obviousley only done to remove any slight warping rather than a serious attempt to increase the compression ratio.The original head width (thickness) is 2.75 inches . I have a 12g295 with .120" skimmed off and still a fair amount of metal left before breaking into the oil passage. Heads obviousley varied in this area.
2.75" thats 69.85mm so if my 12G295 head is 69.5, then its been skimmed? ???
Posted 14 March 2011 - 10:39 PM
Posted 14 March 2011 - 10:46 PM
Posted 14 March 2011 - 10:52 PM
Posted 14 March 2011 - 10:55 PM
Edited by bmcecosse, 14 March 2011 - 10:57 PM.
Posted 14 March 2011 - 11:02 PM
You should start your own thread then - not hi-jack someone elses.......
And we can't answer until we know what pistons you have at present - raised D, dished, flat-top???
Posted 15 March 2011 - 12:19 PM
