Dashpot Oil Change.
9 replies to this topic
#1 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 02 February 2011 - 01:59 PM
My minis running extremely lumpy and bogging down, and I'm not to sure how to go about making it run better, and have read it could be dashpot oil?
It was sitting for a year un-used so I guess it's a good place to start.
Do I literally just unscrew the nob on the top and pull the plunger(?) out, and pour the correct oil in?
What weight oil would it be for a 998cc?
Thanks, Ross
#2 Beej123
Beej123
  • 1,184 posts
  • Local Club: Splinters Mini Club
Posted 02 February 2011 - 02:01 PM
It is that simple!, top the oil up until you can feel resistance when you push the dip back in. I use the same oil that i run in my engine (20W50) but i know some prefer to use a thinner oil
#3 RossKnight
RossKnight
  • 2,539 posts
Posted 02 February 2011 - 02:04 PM
Thankyou, thought I'd ask before flooding my carb with oil or something... haha
Any other things I should look out for or change whilst I'm doing that?
#4 Beej123
Beej123
  • 1,184 posts
Posted 02 February 2011 - 02:07 PM
Bogging down can also be distributor so check all connections to and from and take the cap off to check for and moisture, just give it a wipe with a clean cloth inside and pop it back on, while its off, check the condition of the points, if they are pitted or corroded then your bogging down will soon turn into a misfire.
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 02 February 2011 - 02:08 PM
Don't worry, you can't. Car might give you issues first start but thats just because it has to push some oil out the dashpot.
#6 RossKnight
RossKnight
  • 2,539 posts
Posted 02 February 2011 - 02:12 PM
I never thought of checking for moisture, could be why considering the weather lately.
Can't check until Monday though as it's stored in a barn until I become unlazy and learn to drive :')
I'm guessing it would just burn off anyway? but thanks
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 02 February 2011 - 02:36 PM
Okay, the dashpot when very full will just squirt the oil out of the hole in the plastic cap of the plunger, small amounts work their way down the outside of the piston and get sucked into the engine.
#8 RossKnight
RossKnight
  • 2,539 posts
Posted 08 February 2011 - 03:41 PM
Just been to see my mini today as it's being stored in a barn, I can't work on it everyday...
But it appears the dashpot has oil in.
I started it again and I think the problem is that it's just mis-firing? What could be the cause of this?
I'm going up there again tomorrow so I might check distributer etc, but to be honest I don't know what I'm looking for and I don't know anyone local that would be able that know about minis etc
#9 Beej123
Beej123
  • 1,184 posts
Posted 08 February 2011 - 03:44 PM
Could be coil or dissy (amongst a few other things)
Where about in the world are you then?
#10 RossKnight
RossKnight
  • 2,539 posts
Posted 08 February 2011 - 03:55 PM
What exactly am I checking for, obvious damage or..?
I'm located Near Alton, in Hampshire
Edited by RossKnight, 08 February 2011 - 03:55 PM.
