Stub Stack
Posted 05 February 2011 - 06:18 PM
lightened flywheel, but was told to get a stub stack to even
further improve air flow
so my question is are these stack as good as people say????
Cherrs
Posted 05 February 2011 - 07:05 PM
a stub stack fits inside something like a K&N panel filter
it's like a little ram pipe and is used to smooth the air into the engine
Visards yellow bible would make good reading for you
Posted 05 February 2011 - 07:43 PM
Hi thanks yes i should have said i do have a k+Nyou haven't said what air filter you use
so do they work?
Posted 05 February 2011 - 07:51 PM
Posted 05 February 2011 - 07:59 PM
you won't feel the difference but according to visards book you could pick up a couple of hp
I'm sure Vizard goes further and says that without a stubstack or rampipe a pancake/cone filter is useless!
It's because as the 90degree turn into the mouth of the carb restricts the air meaning that your carb is actually not 1.5" any more. Putting on a stubstack smooths out this turn and means more air can flow.
Edited by huw_jenks, 05 February 2011 - 07:59 PM.
Posted 05 February 2011 - 08:04 PM
Thanks Very interestingyou won't feel the difference but according to visards book you could pick up a couple of hp
Posted 05 February 2011 - 08:42 PM
Edited by bmcecosse, 05 February 2011 - 08:43 PM.
Posted 05 February 2011 - 10:33 PM
Thanks when you put on the stack on to the air filter plateA low cost alternative is to flare out the mouth of the carb - with a good radius all the way round. The restriction of air flow is the vena contracta - and is relieved by the flaring - or the radiused inlet stack.
do you need a gasket
cherrs
Posted 05 February 2011 - 11:22 PM
Posted 05 February 2011 - 11:28 PM
Radius-ing the carb face inlet with around 3/16" radius is probably as good for a road car. They might work on a race car where a few tenths of a second per lap is important.
Posted 06 February 2011 - 09:10 AM
Posted 06 February 2011 - 01:07 PM
