Welding
Posted 05 February 2011 - 06:35 PM
How to you guys get round this.
Please move if i have posted in wrong section.
Posted 05 February 2011 - 06:48 PM
works fine.
ring mains are usually fused to 32 amps and the welder wont draw more than 13 amps as thats the size of the fuse in the plug.
Posted 05 February 2011 - 06:50 PM
Posted 05 February 2011 - 06:51 PM
I'm trying to run a welder off of domestic socket with extension lead, i have read various information saying you can't run of an extension lead with out blowing fuses etc.
if its a 13 amp welder and you use a decent heavy extension lead you will be fine. you will have to make sure you keep the lead out and not coiled up as it will get to hot then start popping fuses and melting cable. you can plug what you like into a 13amp socket as long as you dont exede 13 amps.
Posted 05 February 2011 - 06:54 PM
if the voltage drops the current goes up to compensate
if your welder is running close to 13 amps the extra current from the voltage drop might just take it over and blow the fuse
if you must use a extension lead use one as short as you can and as thick as wire as you can find
i use my camping lead that has 2.5mm cable rather then the normal 1.5 or even 1mm cable
and remember a heater is a coil of wire, leave the lead 1/2 wound up and it will get hot
Posted 05 February 2011 - 07:00 PM
Lots of cheapo extension leads use lighter flex though so you do need to pay attention and you can't just get around that by fitting a bigger fuse as that's plain dangerous.
The point about uncoiling a lead is also good. If you are pulling a decent amount of current through them then a coil of wire can get quite hot as it becomes a heating element. This won't blow the fuse though as you haven't increased the current being drawn until it melts through the insulation and wires touch - that way fires lie and you REALLY hope that the fuse blows first.
Iain
Posted 05 February 2011 - 07:04 PM
Posted 05 February 2011 - 07:13 PM
Posted 05 February 2011 - 07:31 PM
http://www.screwfix....lue-2-5mm-x-50m
just buy a plug for one end and a multi socket for the other
http://www.screwfix....Lead-6G-240V-1m
this cable will far exceed any ready made lead
Posted 05 February 2011 - 07:40 PM
Posted 06 February 2011 - 07:28 AM
i plug my grinder into it aswell as the welder so better safe than sorry
Posted 06 February 2011 - 10:15 AM
Posted 06 February 2011 - 01:11 PM
So all the extensions in the shop are either 5 10 or 20m lengths, 5 and 10m being 1.5mm core and the 20's being 2.5. All the cable is HO7 TRS (Tough rubber sheath), with duraplug plugs and ends on. Companies like stage electrics will sell these ready made up, although its far cheaper to buy a drum and make a few of your own.
http://www.stage-ele...x?code=609-3288
These cables are designed for touring so will be upto most things you can throw at them. I would say its impossible to find a harder wearing extension than these.
Rich
