Riley Elf
Posted 06 February 2011 - 01:11 PM
The rear subframe is shot as are some of the fixings on it. The panel it secures to under the seat has holes in it as does the floor it secures to. The piece of meal that's inside the outer skin just in front of the rear wheel has gone both sides and so has the horizontal piece that's above it that should form part of the rear pocket. There is a hole in the boot floor in the wheel arch.
So, time to replace the subframe, do lots of welding and cleaning to get a good paint prep.
I may have to consider having the front welding done as well, the corner of the floor near the A panel has gone each side. the wings near the headlights have got lots of filler in.
I hadn't planned to start a big restoration yet, but do it later in the year. I may just do the necessary bits then go for full re-spray etc later.
Pics of the areas to come.
Posted 06 February 2011 - 08:39 PM
i am really pleased that there is someone else putting one of thses great little cars back on the road i LOVE mine and they are very few and far between . I cant wait to hear how you get on
Posted 06 February 2011 - 08:58 PM
Posted 06 February 2011 - 09:35 PM
Good to see more people starting though, get some piccies in and let us have a look!
Dave
Posted 19 February 2011 - 12:31 PM
So far the causes are...
1) I had time Wednesday to clean up the areas for a neighbour to weld the panels in, but didn't on the basis it would be raining before he had a chance so get rusty again. It didn't rain, he came round Friday to find out if it's ready and it wasn't. Today, it's raining so I can't clean it up for him to do. Hopefully it will be dry tomorrow.
2) I cleaned the radius arms up and painted them the other day, noticed one of the brake adjuster wedges fell out and picked it up and kept it secure. Today I went to put the brakes back on, found the second wedge had fallen out of that one so still one missing. Only a few £s , but annoying and will delay me.
Oh well, better get some more done in the garage while the car is outside in the wet on the ramps.
Posted 19 February 2011 - 01:27 PM
Posted 20 February 2011 - 09:55 PM
I've got some spare if you need one, but you'll have to pm me where to send it!?
Posted 20 February 2011 - 10:00 PM
Its nice to hear that people are also doing something different to the norm.
keep up the good work.
Edited by roofchoplofty, 20 February 2011 - 10:01 PM.
Posted 20 February 2011 - 10:07 PM
Go the horn working today. after pulling the switch apart, the column shroud off etc I found it was the fuse box (Fuse box! Two fuses, one for the horn and interior light, one for everything else). The constantly on fuse was suffering from corroded contacts, so the broken interior light wouldn't have worked even if it wasn't broken.
Hopefully go the wipers working on both switch settings (single speed motor) had some sort of time delay intermittent system fitted, so while fiddling pulled switch apart and may have lost bit. Not an issue really as it's all mounted in a massive wooden vinyl-covered shelf thing at forehead height, so want to get rid of that and swap to different switches anyway.
For the MOT that leaves the front brake pipe, getting the welding done (should be this week now that patches are all made) and then re-fitting the subframe, suspension and everything that goes with that (fuel tank, re-pressurising the Hydrolastics etc.
Posted 05 March 2011 - 07:58 PM
Replaced one of the front brake pipes between the two slave cylinders, glanced at the other and thought from a distance it was already copper, couldn't work out why I'd have changed one already and not done the one with rust on that failed the MOT. Only after bleeding the brakes I realised the colour was rusty steel not copper. Tomorrow I have to replace the only remaining steel brake pipe and then re-bleed.
Today
Adjusted (lots of filing metal) rear arm brackets to get toe-in instead of toe-out, and correct camber
Refitted petrol tank
Refitted exhaust (couldn't find middle bracket, so will have to obtain oner and fit at later stage).
Pumped up suspension to correct height.
Adjusted brakes
Refitted battery and got it to start.
It's getting there. Bit of filling to do inside where the old metal remains despite new metal being outside (such as companion bins) then I can get the last bits done for the MOT test. It was nice to have it back on four wheels today even if it is still a few feet above the ground.
Posted 06 March 2011 - 08:30 PM
Didn't get the brakes working correctly today, pedal takes a couple of pumps to get a decent pressure. Would assume either air in system (have had most pipes off for a couple of weeks while doing subframe) or shoes too far in so pumping pushes them out far enough. The only thing I've really changed is the valve at the rear, in reality I didn't change it, I used the one on the subframe that I purchased, so that was planned for a swap back to the original one, but before I got to it I decided I'd take the front wheels off and adjust the front brakes.......
Both Track Rod End gaiters gone. OK, nothing much, but I could only find one replacement.
Then I noticed the rust in the front corner of the footwell/ bulkhead area, and I prodded it. Oops. So the rest of the day was taken up with grinding, brushing and cutting & shaping panels to go in . I've now tacked them in place ready to have them welded on by somebody competent.
I'm so glad I bought a second-hand beam jack. it fits on the Carstages ramps and then I just pump it up and the who car is lifted off the ramps, locks into place mechanically (to protect me from hydraulic failure) and it's really stable.
The only other thing I managed to do today was replace the second front brake pipe between the two cylinders, so all copper now.
Posted 06 March 2011 - 10:05 PM
Any pics?
Posted 13 March 2011 - 03:13 PM
Driver's seatbelt didn't look well secured ( two bolts through floor with washers under the floor. Undid the bolts and found one part of the bracket was broken so really just one bold doing the job. Now fitted different style retractable one so it secures to the rear bin.
Carpets still drying so they are not yet in.
Rear bin trims fitted then it started to rain.
Posted 17 March 2011 - 07:06 PM
I still have things I want to do before using it on the road but theoretically I could use it once it's taxed. There is a slight issue taxing it, I cannot find the V5C, so I'll either have to turn out every draw in the house or pay (£15 I think) and admit I've lost it.
