Maniflow Exhaust Fitting
Posted 07 February 2011 - 05:55 PM
First of all, it didn't come with the long middle pipe needed to link the back box to the manifold. After ordering one from the Maniflow website (£40 including delivery!) I have that sorted.
Now, I come to fit the exhaust and it doesn't have the correct fitting brackets! So my question to you guys is...
Will the RC40 fitting kit (http://www.minispare...=...4948&title=) work when fitting a maniflow side exit exhaust? Its the back box which I don't have the correct fittings for.
Thanks for any help!
Posted 07 February 2011 - 06:13 PM
Why wont it let me right the letter you? keeps coming out as you!!
Edited by timmo, 07 February 2011 - 06:17 PM.
Posted 07 February 2011 - 06:15 PM
Posted 07 February 2011 - 06:20 PM
Is it possible to buy the rear box brackets separately? The rest of the exhaust is clamped together, I just can't fit the back box.Ive just fitted a Maniflow sigle side exhaust...made my own brackets up, but yes that kit should be fine....Ahh hang on....think you'll find the "you" clamps will be too small, Rc40 clamps are 1" 3/4 Maniflow system is !" 7/8 so best buy seperate.....
As I brought the kit from the show, unfortunately I have no receipt.Is the seller a reputable company, you say you brought a kit, but its a kit with parts missing, Have you been back in touch. All the bits needed should be with a kit.
Posted 07 February 2011 - 07:02 PM
http://www.minispare...=...4446&title=
http://www.minispare...=...5408&title=
Is that what you wanted?
Posted 07 February 2011 - 07:07 PM
Of all the things I have bought for the mini this was probably the best and easiest fit.
I used the RC40 fitting kit but one of the clamps is too small so I bought an extra one from Halfords (£1 ish rings a bell). Despite this I would still use the kit as it gives you precise brackets for the subframe mounting rather than having to use universal types.
Good luck
Regards
Steve
Edit: Timmo has listed the bits seperately so you still get the correct parts but save a couple of quid.
Edited by stevede, 07 February 2011 - 07:09 PM.
Posted 07 February 2011 - 07:18 PM
I hope you get this sorted, I'm sure it will be worth it once fitted.First of all, it didn't come with the long middle pipe needed to link the back box to the manifold. After ordering one from the Maniflow website (£40 including delivery!) I have that sorted.
Just curious tho, did the kit come in a sealed box? I am pretty sure I would have noticed not getting the longest pipe in the kit.
