This is the gearbox case from my 1380. Its been worn by the idler gear shim. Its not bad about 3/4 thou. Took it to a local machine shop today and asked them if they could weld it up to raise the worn section and then machine it flat again. They recommended simply machineing the whole thing down 5 thou and useing a fatter shim to take up the idler gear slack.
What do you think??
Edited by AndyMiniMad., 08 February 2011 - 05:59 PM.
