Jubilee Clips To Secure Y Piece To Lcb
Posted 09 February 2011 - 12:52 PM
Year: 79
Would it be possible, even if temporarily, to use jubilee clips to secure the Y piece to the LCB? It's a Maniflow LCB/Y piece.
Posted 09 February 2011 - 12:55 PM
stupid censor software changes it to YOU ????
Edited by lrostoke, 09 February 2011 - 12:56 PM.
Posted 09 February 2011 - 12:56 PM
Posted 09 February 2011 - 12:58 PM
Posted 09 February 2011 - 01:03 PM
Well that's what I'm asking. I do have some 45mm/48mm/51mm you bolts (aka exhaust mounts?) but that just doesn't look right to me. Bearing in mind I am a novice.You can get some great clamps from most motor factors, or some even better s/steel ones from online...do you really need to use jubilee clips?
Posted 09 February 2011 - 01:05 PM
Posted 09 February 2011 - 01:31 PM
Just thinking between Mikalpr clamps, or this one extra exhaust mount I could use. If there's no point using a jubilee clip.
Posted 09 February 2011 - 06:16 PM
Edited by cooperrodeo, 09 February 2011 - 06:20 PM.
Posted 09 February 2011 - 06:24 PM
Posted 09 February 2011 - 08:35 PM
Posted 09 February 2011 - 08:49 PM
You'll never get the common type 'you' exhaust clamps to fit between the two downpipes on the 'Y' piece. either buy the Mikalor clamps. Or buy the Maniflow calmps. Me personally will never use those useless things again, Mikalor every time!!
you can get the normal type clamps to fit, if you modify them a bit, by grinding both down, works fine for me.
Posted 09 February 2011 - 11:02 PM
Edited by mra-minis.co.uk, 09 February 2011 - 11:04 PM.
Posted 10 February 2011 - 08:55 AM
Posted 10 February 2011 - 03:53 PM
