Removing Rear Bulkhead...
11 replies to this topic
#1 nickhead
nickhead
  • 78 posts
Posted 09 February 2011 - 11:56 PM
Hi Guys, i know this is a big one on here, i've done some reading but can only find snippets of peoples opinions on the implications of removing the rear seat/bulkhead.
im planning to run a sealed fuel cell, i will be running a custom cage that will be mounted to rear turrets for coilovers, then across between turrets, so i dont think strength will be lost or an issue,
i also plan to remove/replace the boot floor with carbon or fibreglass.
i'd appreciate anyones opinions and experience with the removal, issues with strength, issues with mot etc etc..
many thanks,
Nick
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 February 2011 - 08:02 AM
have you read the rules on modifying a monocoque and loosing the cars identity
http://www.the-ace.o...dification.html
there is also the MOT problem with modifying the construction with in 30cm of the subframe mounts
#3 nickhead
nickhead
  • 78 posts
Posted 10 February 2011 - 10:44 AM
surely a mini isnt monocoque!
ill be fitting a carbon front end, amongst other bits anyway so its not going to make it any worse.
also ill be running a beam so no subframe as such.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 February 2011 - 02:03 PM
yes a mini is a monocoque, 2 subframes don't make a chassis
what you want to do is still all do able, you just need to test and register the car afterwards
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 February 2011 - 02:18 PM
Well the exact type of what's mounted isn't really the issue, it's still a mounting. This isn't actually a problem at the MOT though, the MOT looks for corrosion damage and weakness. If whatever is modified is at least as strong as the original it will pass. Panels that have been removed are not tested for or a reason for failure, only corrosion.
#6 nickhead
nickhead
  • 78 posts
Posted 10 February 2011 - 03:38 PM
okey dokey, has anyone removed theirs before?
any pictures? any issues they have noticed?
#7 GraemeC
GraemeC
  • 7,440 posts
Posted 10 February 2011 - 06:39 PM
Yes, I've done it. It can make the top half of the shell prone to moving as you will remove all the cross bracing - nothing on the cage will replace that unless you tie it into the B and C pillars.
The car will also be very noisy as the sound will bounce around the cabin and you will have less crash protection.
Having been there and done it, to a competition car, I wouldn't do it to a road car.
#8 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 10 February 2011 - 07:00 PM
I've just gone through the process of putting all this back in again ( bought an abandoned Z car project ) - without it the shell flexed hell of a lot - putting it back in made a lot of difference :thumbsup:
#9 nickhead
nickhead
  • 78 posts
Posted 10 February 2011 - 10:45 PM
hmmmm
thanks guys, ill give it some big thinking before i make my mind up.
any pics of them?
#10 Tupers
Tupers
  • 4,156 posts
Posted 10 February 2011 - 11:25 PM
We removed the rear seat back along with all of the rear floor from the heel bard back on the Alan Carruthers Mini. Clicky
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 11 February 2011 - 07:49 AM
Tupers - you took ever so slightly more out than me, but you replaced the floor with stiffened, welded steel so that would've put some rigidity back in - mine was a rivetted alloy panel!
For pictures of mine see my green build thread link in my sig.
#12 nickhead
nickhead
  • 78 posts
Posted 11 February 2011 - 06:57 PM
how did you find it for loss of strength Tupers?
