What Size Fuse Is The Headlights And Tail Lights
7 replies to this topic
#1 mini_matty
mini_matty
  • 46 posts
  • Local Club: Not yet but looking for one
Posted 10 February 2011 - 08:03 PM
hey guys myfuse for my rear lights has gone and ive replaced it and the headlights now work but the tail and speedo lights dont.
the fuse i took out had 8amp and 15 amp on the fuse and i replaced it with a 8 amp fuse which has only fixed the headlights so im woundering if ive just made a basic mistake?
cheers
#2 S2000Steve
S2000Steve
  • 145 posts
Posted 10 February 2011 - 08:34 PM
What kind of fuse box do you have?
Blade type or old "four-fuse fuse block?
1. Top fuse is 35 amp.
2. next is 25 amp
3. then 25 amp
4. Bottom is 15 amp.
This is assuming a four fuse on later models and its wired up correctly.
#3 MRA
MRA
  • 7,607 posts
Posted 11 February 2011 - 09:26 AM
Headlights are not on a fuse.
two readings on the fuse... this means that it's the oldglass type fuses...
I suspect a bad connection
#4 DAVEY_C
DAVEY_C
  • 555 posts
  • Local Club: irish minis owner club
Posted 11 February 2011 - 12:38 PM
sorry to hijack your post mate
my rear driving lights aren't working either nor are my dash lights, all other rear lights including brakes work.... i put a single filament bulb in the rear and no drive lights still didn't work... although when i press the brake with a single in my dash lights and front sidelights come on anf off with the brake light?? any ideas on where to start??
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 February 2011 - 12:43 PM
Put the right bulbs back in the rear for a start, the wrong bulbs are shorting out the lamp holders and causing the issue with the front sidelights and dash. Have you checked the fuse?
#6 mini_matty
mini_matty
  • 46 posts
Posted 11 February 2011 - 12:45 PM
thanks for all your help guys ive now fixed the problem i found that it was the fuse holder having a bad conection with the fuse a quick clean and jobs a good'n
#7 DAVEY_C
DAVEY_C
  • 555 posts
Posted 11 February 2011 - 12:55 PM
yea i only changed bulbs as a means of trying to find the fault but didn't so changed them back straight away.... yea i checked fuses, all look fine as do connectors, i thought it may be a faulty earth somewhere??
#8 Yoda
Yoda
  • 1,958 posts
Posted 11 February 2011 - 01:21 PM
What a coincidence!
I have just got back from a local guy with the same issue, sidelights coming on with the brakes and it was exactly the same answer, wrong bulb in the unit, A single filament one LOL.
