hello all new here.
im 15 and have my own suzuki samurai jeep that im modding for offroad use, 1 problem carbs are poo
so im after a HIF44 carb with manual choke.
im looking on ebay and finding alot of HS4 carbs and they look identical to the HIF44
if any one in the greater manchester area and surroundings has a the SU carb i need i would be willing to buy 1 for beer tokens
:tongue:
thanks Luke.
SU carb's
bailey
, Dec 30 2005 06:50 PM
7 replies to this topic
Posted 30 December 2005 - 06:50 PM
Posted 30 December 2005 - 06:51 PM
hs4's are not identical looking to a hif44, i dont htink i have any 44's at the moment but have ahif38 i can post to u
dave
dave
Posted 30 December 2005 - 06:53 PM
nope the hif38 wont do these are alright with an sj410 (1.00
buts mine an sj413 runing a vitara engine 1.6
so need the hif44
thanks any way
do you know if the hs4 has manual choke, and basically do the job?
so need the hif44
thanks any way
Posted 30 December 2005 - 08:49 PM
the HS4 is tha same size as a HIF38...both are 1" 1/2 carbs. the difference between em is that the HIF has the float bowl built into the bottom of it rather than on the side like a HS.
If you are after a HIF44 you could also use a HS6 both are 1" 3/4 with manual chokes, but the HIF is a lot better IMO.
Posted 30 December 2005 - 09:33 PM
ahh i see what u mean this is why i was confused as he calls it an hs4 but according to what u just said it must be a hif44 as the float chamber is on the bottom
the hif6 is a 2.00" as ive got about 4 of those off rover v8s tried 1 already
http://cgi.ebay.co.u.....AMEWA:IT&rd=1
Posted 30 December 2005 - 09:41 PM
i cant use the earlier type of carb with float chamber at side becasue it will hit the master cylinder
Posted 31 December 2005 - 09:49 AM
No, no no no no.
The HIF 6 is the same as the HIF 44. The same carb, except the 6 is milled out using an imperial sized cutter of 1 3/4" and the 44 is done using a metric cutter of 44mm, which are very similar sizes. Imperial sized SU carbs are marked up in 1/8s of an inch over 1". So a 6 is 1 and 6/8 of an inch, which is 1 3/4".
HS 6 carbs are the same size, as they are also 1 and 6/8".
HS 8 carbs are 1 and 8/8", or 2" in English.
I don't believe there actually is a 2" HIF carb.
Posted 31 December 2005 - 01:11 PM
ahh write must be the HS8 that ive got then
any 1 got an hif44 then
thanks for the info so far good forum :grin:
