1977:
Hi, I wonder if anyone could please help me, everything seems to be going wrong with my mini
Edited by Gjevans4, 12 February 2011 - 10:39 PM.
Posted 12 February 2011 - 08:25 PM
Posted 12 February 2011 - 09:23 PM
Posted 12 February 2011 - 09:36 PM
Hi,
First, if your light relays are blowing and the wires are melting then it's likely that you have a short circuit on your headlight. Maybe a bulb mounted incorrectly or a wire chafed. Headlights are not fused so that's why everythings melting, they'll keep pulling as much power as the battery can provide until the wire melts!
Fuses:
Top 1 35amp Stoplights, Revrsing lights, heated rear window, indiators and dim dip relay.
next down: Horn, main beam flash,brake circuit, radio memory
3rd down: Heater motor, Windsren wipers, instruments
bottom: Tail lights, instrument panel lights.
I tend to stick mainly to electrical and let others preach the mechanics as i;m not qualified in this area.
Hope this helps
Bob
