Small Amount Of Smoke Coming From The Air Vents
11 replies to this topic
#1 DanRobinson
DanRobinson
  • 138 posts
Posted 13 February 2011 - 06:49 PM
Hi, my 87' Mini Advantage started smoking today for the first time ever. the smoke smelt kind of sweet - not like a burning smell.
it was coming from the air vents that heat the screen and only lasted a few seconds but i have no idea what it could be. i have taken the dash of this morning and replaced my speedo so i may have caought some of the old electrics and they may have burned out but im not sure. i havent noticed anything going wront with it since.
Any ideas?
#2 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 13 February 2011 - 06:56 PM
Perhaps it wasn't smoke but steam, and the sweet smell is engine anti freeze? That'd be the case if you have a pinhole in your heater matrix.
#3 DanRobinson
DanRobinson
  • 138 posts
Posted 13 February 2011 - 06:59 PM
That would make sense. the smoke looked a little too dense to be fire. but i thought i might have burnt out a socket or something
#4 Bradfirj9
Bradfirj9
  • 28 posts
Posted 13 February 2011 - 07:40 PM
A word of advice, Ethylene Glycol is reasonably toxic. Probably not in the quantities you're dealing with, and usually only by direct ingestion, but you can never be too careful.
Edited by Bradfirj9, 13 February 2011 - 07:42 PM.
#5 CLASSIC-MINI-BITS
CLASSIC-MINI-BITS
  • 493 posts
  • Local Club: LCMOC.COM
Posted 13 February 2011 - 07:44 PM
we see it all the time, it is a common thing this time of year, it will be the matrix leaking slightly, sort it asap as it is toxic.
#6 DanRobinson
DanRobinson
  • 138 posts
Posted 13 February 2011 - 07:50 PM
How can i sort it?
#7 Timtom
Timtom
  • 2,143 posts
Posted 13 February 2011 - 08:22 PM
and don't lick your windscreen..
BECAUSE YOU MIGHT DIE.
#8 Brad_Raybould
Brad_Raybould
  • 421 posts
  • Local Club: Bostin' Mini Club
Posted 20 April 2012 - 12:15 PM
I know it's an old post but I get this problem in cold and damp mornings mainly, I first noticed this in December and recently started again now we are having a few cold and wet mornings. I was also wondering if there is a way to fix this problem.
#9 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 20 April 2012 - 12:29 PM
This sounds like your heater matrix is leaking. I had the same problem on mine. I replaced the matrix and have had no problems now with it.
#10 reallybig
reallybig
  • 613 posts
Posted 20 April 2012 - 12:38 PM
i removed my matrix and put a bypass hose in
couldn't be arsed to spend £50 on a new matrix
#11 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 20 April 2012 - 01:53 PM
The only proper fix is to replace the matrix. Don't bother with rad weld etc. No they are not the cheapest items but if you bypass your matrix then no heat.
#12 TORZIEnJIM
TORZIEnJIM
  • 683 posts
Posted 20 April 2012 - 09:00 PM
Made me lol
