Mould On Mini Seats
7 replies to this topic
#1 pothole
pothole
  • 317 posts
Posted 14 February 2011 - 11:48 AM
I bought a very expensive cover for my mini last year to protect it from the winter months. I have just uncover it today and to my dismay there is all mould over most of the interior inside. I have tried to clean it off with an upholstery cleaner but it has left black spots that will not come off. The mini is a Sidewalk with the tartan interior so rare to replace if I have too. On the plus side connected the battery and started first turn of the key, but the interior looks awful any ideas what I can do to remove the black spots.
Thanks pothole
#2 minimad82
minimad82
  • 320 posts
Posted 14 February 2011 - 11:54 AM
Thanks pothole
had the same prob with my old rs turbo bathroom mold remover worked for me..oh next time you use the cover leave the windows open a bit the mould is caused by the car sweating inside good luck
#3 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 14 February 2011 - 12:00 PM
Thanks pothole
Its because your mini was damp when you put it away. I'd do a thorough check under the carpets, rear bins ect to see if any rust has formed. I've stopped using my cover. I found it made my mini worse.
#4 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 14 February 2011 - 12:01 PM
cover wont cause the mould - some other interior activity would have started that off :techsupport: but without air movement you've created a perfect greenhouse for it to thrive in :thumbsup:
mould remover as mentioned above works well - and maybe a good VAX to deep clean it properly :cry:
#5 hoppys r1 mini
hoppys r1 mini
  • 22 posts
Posted 14 February 2011 - 12:09 PM
You can by a steam cleaner that gets right into the seat an cleans all the crap out
An if you do it properly it will make them look brand new
Make sure you leave the heater on for a wile to dry them out ..
Good look
#6 bobs
bobs
  • 512 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 14 February 2011 - 12:18 PM
Big caravan silica gel packs are good if you're storing your car under a cover outside during winter...
Soak it up.
#7 wardyxxx
wardyxxx
  • 1,327 posts
Posted 14 February 2011 - 12:39 PM
Soak it up.
+1
I've got re-usable ones in the mini in her garage. Stops the condensation which leads to the dreaded tin worm!!!
#8 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 14 February 2011 - 04:23 PM
Soak it up.
This is a good idea, but even leaving tray full of cat litter in the car can a big help with absorbing moisture from the air :closed: (but if you leave the windows open do make sure that no cats can actually get in, otherwise it could be quite unpleasant if your mini is used as public convenience over the winter, by all the felines in your neighborhood!! :thumbsup:)
Edited by AVV IT, 14 February 2011 - 04:24 PM.
