Nice forum by the way, very clean looking.
I've just acquired a single motorcycle trailer that has mini rear hubs. The wheels had a fair amount of play so I thought I give them a look over and maybe re-grease and re-adjust them. I'm pretty familiar with rear wheel bearings (but not mini ones) and was expecting to find tapered bearings in there - wrong!
Firstly the hub did not want to come off, so I used a length of wood at the rear and hammered it outward. It suddenly gave but only moved 20mm or so.
Undeterred by this I attached a 3 jaw puller to the hub and wound it off. Once clear I saw that these hubs have what I assume (after reading some of the previous posts on here) are the older style ball bearings in them and that due to the separate spacer becoming seized I had ripped apart the inner or rear bearing - which is no loss as these bearing are done anyway.
So my trailer has now been left with one side propped up with house bricks until I decide what to do now.
My questions are,
What's the best way to proceed with trying to remove the spacer which is rusted pretty solidly to the stub axle?
Do I need to worry about retaining the spacer - if not then the dremmel will be out and no doubt it'll be off in about 5 minutes.
Fitting replacement taper roller bearings - new issue..
I'm not overly sure about using spacers with tapered bearings. All the trailers I've seen that have tapered bearings don't have spacers, in fact neither do the cars. The last one I did was '96 VW Golf and there was no spacer. To set the tightening force you tighten the nut until the keyed washer behind it can only just me moved with a screw driver, then pop a castle crown over the nut and lock it with the split pin.
That is a good system which is easy to set and solid.
I notice that the mini's system doesn't use a keyed washer and also has a castled nut, this might give me an issue as there are only a limited number of positions that the castle nut can be locked into.
So does that mean that I no choice other than to find bearing of a suitable quality with built in spacers, or somehow remove the original spacers and re-use them. In which case I refer back to the first question - any tips on a method to get the spacers off?
Cheers, Rich.
Edited by Rich's trailer, 14 February 2011 - 02:18 PM.
