Acid Dip/bead Blasting
9 replies to this topic
#1 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 14 February 2011 - 08:56 PM
Want to get my Revolites totally stripped back.
Fed up of using rubbish nitromors with no effect.
Whats the best? Dip or blast?
Where can i get it done around the Stourbridge/Dudley/Wolvo area?
#2 march717
march717
  • 47 posts
Posted 14 February 2011 - 09:33 PM
have a word with surface proccesing in dudley 01384 242010 not100% sure if they can do ally though
#3 Carlos W
Carlos W
  • 10,114 posts
Posted 14 February 2011 - 09:37 PM
I've had alloy motorbike wheels sandblasted in the past, but it was by a company in Newcastle!
http://www.bettablas...t/motoring.html
#4 Cooper-202S
Cooper-202S
  • 201 posts
Posted 14 February 2011 - 10:04 PM
You might want to look around for soda blasting companys, this is something relativly new so there may not be anyone in your area.
The advantage is that this method avoids the possibilities of either chemical reactions between the dipping chemicals and later the paint,
or removes the possibility of surface errossion caused by the use of sand or grit.
Some stripping chemicals have proven difficult to isolate long term , though this has tended to be more on body shells, particularly seams and joints.
and depending on the detail of the wheels some of the aris detail or accute edges can be lost if the sand blasting is done with ordinary grit meant for steel.
If you cannot find a Soda blaster then I would say bead blasting would be the prefered option.
#5 Cooper-202S
Cooper-202S
  • 201 posts
Posted 14 February 2011 - 10:10 PM
I found these guys they may be able to help
http://www.soda-blast.co.uk/
Soda-Blast-Systems (UK) Ltd
River Lee Road
Tyseley, Birmingham
West Midlands B11 2JG
T: 0845 644 8611
I have used the guy in St Albans on blocks and sub frames and it seems to work pretty well
#6 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 15 February 2011 - 09:49 AM
theres a place in brum (almost in the city centre, digbeth)
who will strip then powdercoat any mini wheel (up to 16's i think) for £15 per wheel.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 February 2011 - 11:26 AM
feck that's cheap...
I charge £10 a wheel to dip & strip then you're looking somewhere between £15 and £40 for powder coating a wheel depending upon the number or processes required... so minimum £25 a wheel + VAT
#8 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 15 February 2011 - 11:31 AM
What's the best way to strip the old paint/powdercoat off yourself? Shot blasting is a bit aggresive on ally, bead blasting is good but the glass bead gets worn out very quickly and turns to powder, nitromors as said isn't great at wheels...!
#9 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Wherewherewherewhere
#10 maggies_minder
maggies_minder
  • 4,393 posts
Posted 15 February 2011 - 12:39 PM
they are called bournespowdercoating, just google that.
obviously the bigger the wheel the more it cost but both my uncle and a good mate have used them and said they are bang on they both had 18's and it cost them about £20 iirc,
i decided to do my wellers myself, though with the amount its cost me to do them i wouldve been better off paying this sort of price.
Edited by maggies_minder, 15 February 2011 - 12:40 PM.
