Mmmm, interesting - I trust your judgement hugely, Mr Sprocket!
Out of interest - What's the reasoning behind keeping the side-mounted rad?
The reason that I thought about changing to the proper front mounted rad, was to eleviate any anomolies, mainly for maintenance and upkeep, really.
It currently has a side-mounted rad, with an SPi bottom hose setup. The problem we found was with the temperature sensor and sandwich plate - This could be moved onto the head, I presume? (in the old heater-tap recess?)
I have never had an issue with cooling with the side mounted rad. The issue that I have had was with the temperature sensor & getting the correct reading?
As I say, the only reason I thought it was best to change back is that I now have access to the proper full setup, and figured it was there for a reason? Seeing as the gearbox has blown and the engine is out (and the body is in bits) - I thought it best to take the time to look over the best ways of doing things!
It seems that there was no additional strengthening that went into the MPi subframe, then - So I think it might be worth sticking to the original?
Not so bothered about the rear subframe - I'll be using the current 1 1/4 exhaust setup that's on it, so happy with that!
Cheers all!
