Bought from a previous owner and then moved to unit and stored until now .
Has all its glass , doors , bootlid and a black bonnet .
Its doors also which will need a reskin each .
The shell has rust in rear quarters and rear door bins ( Worst bit of the whole car ) , windscreen scuttle is in good condition but could do with both ends doing as looks bubbly on paint in those areas on the seam with wings .
Front wings are pretty good , even under the headlights is ok with just surface rust / pitting
Lower slam panel is out of shape , easier to buy repair section than straighten imo .
Roof and gutter / pillars are all good , no holes or rust etc .
Sill i cant say as not looked but always a suprsie to be had there no doubt .
Door steps are fine by appearance , A panels will need replacing imo .
Previous owner had done work on the car in places .
Still fitted with its original , complete , hydro-lastic suspension setup and on 4 steelies rolling about no problem and fitted with its steering rack and collum plus top and bottom dash rails and cluster of clocks .
No engine in the car but rose jointed drive shafts remain .
Drum brakes all round with brake and fuel pipes still in place .
Comes with its petrol tank and set of front and rear lights and some of its seats / interior .
Viewing welcome at the unit which is located in kingstag , just beyond sherbourne near sturminster newton .
Give me a shout on my mobile if you want anymore info on 07767075001 , this car is up for £350ono !
Sadly no photos as my phone is from the stone age and the digi went for a dip in a 4ft puddle .... But as always viewing is welcome !!!
Edd
