Model: Mayfair
Year:1989
So, just hopped into the ladies Mini to find that the rear lights turn on the moment the ignition key is turned (light switch is not turned on), and that the brake lights don't appear to work.
Is this indicative of any particular part or connection failure? It's dark now, so I'll have a dig around tomorrow morning, but it might help speed things along if any of you kind folks have any tips.
by the way: The car is 100% factory.
Thanks in advance!
Rear Light & Brake Light Problem
fandango
, Feb 21 2011 08:01 PM
5 replies to this topic
Posted 21 February 2011 - 08:01 PM
Posted 21 February 2011 - 08:07 PM
sounds like the brake switch is either out of adjustment or faulty. have a look at that first it screws on at the top of the brake pedal
Posted 21 February 2011 - 08:10 PM
The only thing that comes immediately to mind is a dirty fusebox. Take it off the bulkhead and clean the back of it, clean all the terminals and give them a smear of Vaseline once reconnected. Give the back of the box a thin coat too. If it does turn out to be this, ultimately a new fusebox is the best cure.
Posted 21 February 2011 - 10:11 PM
Thanks guys, I'll start with your suggestions.
Posted 22 February 2011 - 12:37 AM
I would start with the brake light switch on the pedal, sounds like it's stuck on all the time.
Posted 22 February 2011 - 03:58 PM
wassupcrew and MacroMan were both right - It was a dead brake pedal switch, and in fact it was the brake lights being permanently on.
While I was at it I took the liberty to clean up the fusebox, sorted out the dirty door light switches, and fixed a broken wire on the brake reservoir cap.
Thanks guys, your suggestions were really helpful.
