How Do You Remove A Standard Phillips Rover Radio?
TopGearRules
, Feb 22 2011 02:28 PM
4 replies to this topic
Posted 22 February 2011 - 02:28 PM
Model: Mini Mayfair
Year: 1991
Description of problem (please be as in depth as possible): How do you remove a standard Phillips Rover radio?
Hello, im just wondering how you remove the standard Phillips Rover radio including the brackets from a mini. The Haynes manual doesn't give the full instructions so im just wondering if anyone could help me with some guidance? I want to do this as im going to fit a new CD radio player into my new dashboard. Thanks!
Year: 1991
Posted 22 February 2011 - 03:31 PM
If you've got a dash in it will make it a bit trickier. You need to lift the front parcel shelf liner and underneath you will find some srews, two in the front rail and one at the back by the bulkhead. The front edge of the bracket is screwed directly through the shelf, the back is held to the shelf by a bracket.
Posted 24 February 2011 - 01:21 PM
Hey Dan, thanks for the info, got the radio out now!
However i dont know how im suppose to take the arial wire/lead out from the radio? Theres a torx screw next to it on the radio, un did it but it wouldn't come out!
Please help! Thanks, Alex
Posted 24 February 2011 - 02:24 PM
Pull it!
Posted 24 February 2011 - 02:59 PM
Pull it!
Oh, i knew that!
Thanks for the help!
