Rocker Switch Replacement
Hegnirst
, Feb 23 2011 11:33 PM
8 replies to this topic
Posted 23 February 2011 - 11:33 PM
for just a on/off switch (a nice metal toggle) what do i use for the brake testing, fog lights, hazards and demist rockers? is it a certain type?
AND for the lights, because it has dim, full and off, what switch do i use for this? thankyou
Posted 24 February 2011 - 11:54 AM
'Fraid the hazard switch cannot be replaced with a conventional rocker switch without adding a little electrical trickery.
Posted 24 February 2011 - 12:39 PM
i just want a switch, why is it not possible?'Fraid the hazard switch cannot be replaced with a conventional rocker switch without adding a little electrical trickery.
thankyou
thanks, i will have a look D
Posted 24 February 2011 - 01:23 PM
The Mini hazard switch is a six pole single throw switch custom made for the application. From memory, when OFF, two out of the six poles are connected together and the other four are not connected together. When ON, these two poles are separated and the other four poles are connected together. It is possible to use other switches, its just not a straight swap.i just want a switch, why is it not possible?
Edited by SolarB, 22 May 2011 - 10:58 AM.
Posted 24 February 2011 - 02:22 PM
A 4 pole double throw toggle switch will replace the hazard switch with no other electrical work needed.
Search for a thread called 'flicky switches' from 2004 with me posting on it. I listed all the toggles needed to replace every switch in the car, it was my first reply here!
Posted 25 February 2011 - 01:40 AM
thankyou, this (i think) has answered it all
