Tips For Removing Plug Welds
6 replies to this topic
#1 Impy
Impy
    Just On Tickover
  • 5 posts
Posted 24 February 2011 - 09:45 PM
Hi everyone
I'm currently in the process of removing body panels which have been plug welded on. It's my first time at removing panels and I'm struggling to remove some of the welds.
Does anyone have any tips that would help me?
Thanks in advance!
#2 grahama
grahama
  • 2,442 posts
Posted 24 February 2011 - 09:49 PM
Hi,
get a spot weld drill bet form fleabay, 8mm, does them a treat.
Graham
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 24 February 2011 - 09:59 PM
If they are plug welds and not spot welds a spot weld drill may not work as it depends on the size of the plug weld. On average they are normally 1/4" for plug welds whereas spot welds are generally smaller. You can get larger spot weld drills but it is difficult to find the centre of a plug weld especially if it has been ground down flush and polished up.
If push comes to shove you can grind down onto them or just cut along the panel edges to remove the panel and then grind away the old flange.
If it is an original spot weld then use the spot weld drill bits or you can use a 1/4" drill bit which is how i do them, just do not go all the way through.
Edited by sonikk4, 24 February 2011 - 10:02 PM.
#4 grahama
grahama
  • 2,442 posts
Posted 24 February 2011 - 10:15 PM
>_<
sorry, must stop drinking beer with footy on telly before posting as if I know what I am talking about !!! Missed the PLUG bit, thought it was just spot welds .
oops,
Graham
#5 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 25 February 2011 - 08:03 AM
the grinder is the way to remove them.
#6 Impy
Impy
    Just On Tickover
  • 5 posts
Posted 25 February 2011 - 12:09 PM
Thanks for the tips! I had made the school boy error using a spot weld drill bit, it lasted 5 welds!
Grinding it is then....
Thanks again
#7 DAVEY_C
DAVEY_C
  • 555 posts
  • Local Club: irish minis owner club
Posted 25 February 2011 - 01:14 PM
i use a spotweld chisel too and its very handy for if i didn't manage to drill through centre of the spotweld.....
