Dash Padding
9 replies to this topic
#1 vincieshile
vincieshile
  • 42 posts
  • Local Club: not yet
Posted 25 February 2011 - 02:52 PM
I need help. I can't figure out how to fit the top dash padding (haven't tried the lower one yet). The two bolts at the ends are no problem but there is another bolt in the centre - where does it go? There is no hole except the cut-out for the ashtray and if I force the bolt until it slips into that hole then the padding is tight against the windscreen and won't drop down past the rubber. What am I doing wrong?
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 25 February 2011 - 04:39 PM
i got a 72 1275GT reshelled into a later 70's GT and it has 4 oval shaped holes all along the dash rail. they should jsut plop in and then do up the nuts. if u cant see the 4 oval shaped holes then drill some new ones. whot hurt :thumbsup:
#3 vincieshile
vincieshile
  • 42 posts
Posted 25 February 2011 - 05:17 PM
Thanks. That's just the sort of thing I was planning but decided to ask here first in case there's some easy way that I'm overlooking.
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 25 February 2011 - 05:29 PM
That's the wrong advice though, very few Minis indeed have a 4 bolt top dash rail. Your car uses the ash tray hole for the centre fixing, with a clamp that goes across the hole to secure the stud. The padding is supposed to be hard up against the screen seal, but it's really meant to go in before the screen which is why it's tricky to do it this way. Get it in place and then give it a good rattle around and it will settle down.
#5 vincieshile
vincieshile
  • 42 posts
Posted 25 February 2011 - 05:47 PM
Thanks Dan. So that's where the centre bolt goes. Would I be right in saying that the padding should be wedged in between the screen seal and the dash rail?
#6 M44K TS
M44K TS
  • 3,104 posts
Posted 25 February 2011 - 08:12 PM
Yeah, I had to really manipulate mine to get it to fit, (read: hit it quite hard a few times for it to slot into place) Ideally having the windscreen out is the best time to fit one. Just keep at it and it should eventually fit. As for the centre clamp, it's just a small c shaped bit of metal with a hole drilled in it so it bridges the ash tray.
#7 vincieshile
vincieshile
  • 42 posts
Posted 25 February 2011 - 09:27 PM
Thanks for suggestion. Will try tomorow.
#8 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 26 February 2011 - 02:01 PM
wos gonna say it might be specific to the make and model..sorry for any confusion
#9 vincieshile
vincieshile
  • 42 posts
Posted 26 February 2011 - 02:21 PM
During the restoration many little things were changed. For example the windscreen wouldn't fit until 16 mm were cut off. New rubber was fitted. So space between the top rail and windscreen may not be what it should. I am convinced that alterations will have to be made. Anyway thanks to everyone for your time and help. Vincent
#10 vincieshile
vincieshile
  • 42 posts
Posted 23 March 2011 - 07:48 PM
Finally solved the problem by bending forward the bolt the goes down into the ashtray space. I made a bracket for it and tighened a washer and nut until all was pulled into place. Thanks for all the suggestions.
