Classic Mini Metro 998 Engine A+... Will It Fit?
5 replies to this topic
#1 shep_cobain
shep_cobain
  • 157 posts
Posted 25 February 2011 - 06:56 PM
Will a Classic Mini Metro 998 engine A+ and gearbox attached fit straight into my mini or do i need to change some components on the engine?
My mini is a 1984 Austin.
Thanks.
#2 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 25 February 2011 - 07:26 PM
yes it will fit ,
you just have to take the metro engine mounts off and swap them over with the mini ones.
and if your old motor is an non vetro clutch . you might need to get a vetro kit to use on the metro motor , bracket arm and slave etc
#3 shep_cobain
shep_cobain
  • 157 posts
Posted 25 February 2011 - 07:43 PM
yes it will fit ,
Ive been told that i need to change long clutch arm and thats it...
IS this true or is there anything else like flywheel etc?
Its a box and engine.
#4 jfbento
jfbento
    Just On Tickover
  • 6 posts
  • Local Club: Clube Mini Portugal
Posted 02 March 2011 - 06:05 PM
No confusion here. if the arm is the long one is pre-verto type inside, otherwise with short arm is verto type inside. You can´t just change only the arm. There's more than that.
Just put the engine in and buy this:
- Clutch Slave cylinder
- Slave cylinder bracket
- Long bolt to fit bracket
- Spacer between bracket and clutch housing
- Use the same CLUTCH PUSH ROD of your mini
- Hose for verto type
and that it for the clutch.
A few more modifications to the water circuit to be as in the mini and is done.
cheers
#5 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 02 March 2011 - 06:08 PM
Worth changing the thermostat housing over too if you can. Its angled differently on a metro.
#6 jfbento
jfbento
    Just On Tickover
  • 6 posts
Posted 02 March 2011 - 06:12 PM
cheers
