Rear Brake Drum
15 replies to this topic
#1 rawky
rawky
  • 419 posts
Posted 26 February 2011 - 10:55 AM
1992 Italian Job
Hi everyone,
Just a quick one, will my rear drums on my car have/need a spacer when I come to change one of them this week? Just so I know before I order.
http://www.minispare...ty=pb&pid=36485
or
http://www.minispare...=...5841&title=
Cheers!
#2 Ethel
  • 26,055 posts
Posted 26 February 2011 - 11:01 AM
You'll need spaced drums, or separate spacers.
#3 MiniLuke
MiniLuke
  • 1,205 posts
Posted 26 February 2011 - 11:11 AM
Why are you changing one of them?
#4 rawky
rawky
  • 419 posts
Posted 26 February 2011 - 12:24 PM
The brake on one side turns 3/4 of a turn, then binds, then moves freely again. I suspect the drum is warped?
#5 rawky
rawky
  • 419 posts
Posted 26 February 2011 - 06:15 PM
Bump
Am I right in my diagnosis?
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 26 February 2011 - 06:27 PM
Not necessarily (although possible of course) - could be wheel bearing problem, or a 'rusty patch' on the drum rubbing face. I would clean and swap them side to side and see what happens first.
Edited by bmcecosse, 26 February 2011 - 06:32 PM.
#7 chadders15
chadders15
  • 393 posts
Posted 26 February 2011 - 06:28 PM
When changing you must change both at the same time, also some people reccomend changing shoes aswell.
Same thing with discs and pads
#8 rawky
rawky
  • 419 posts
Posted 26 February 2011 - 09:52 PM
Hmm ok, I'll do that. I haven't heard anything from the bearing, but I'll take the drum out and take a look.
Ah I hadn't considered that, cheers
#9 rawky
rawky
  • 419 posts
Posted 25 June 2011 - 09:33 AM
I have since replaced the pads and drums, and also new handbrake cables. However this still persists, at slow speeds the rear right drum groans rhythmically, as if it is binding every three quarters of a turn...
Could the stud axle be bent or something?!
#10 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 25 June 2011 - 10:13 AM
YOU CHANGE BRAKES IN PAIRS!
YOU NEVER EVER THINK OF REPLACING JUST ONE SIDE!
#11 rawky
rawky
  • 419 posts
Posted 25 June 2011 - 12:10 PM
Take your headphones out, you're shouting :lol:
I haven't, I replaced both sides. Any ideas anyone?
#12 Ben1400
Ben1400
  • 40 posts
  • Local Club: Plymouth MC South West MC
Posted 25 June 2011 - 01:12 PM
When you say it is binding do you mean with the wheel clear of the ground it requires some force to rotate the wheel or is it just gently rubbing/catching? If the latter back off the adjuster a couple of clicks and try again. When fully assembled new shoes and drums will always have a high spot.
I tend to adjust the brakes so this high spot just becomes evident by the gentle rubbing sound. Have you run the vehicle far since changing the parts?
You didn't mention the results of looking at the bearing, whilst on axle stands (Safety) with the wheel fitted can you grasp the wheel at 3 & 9 o'clock and try to rock the wheel, is there any play? Try the same at 12 & 6 o'clock.
Hope This Helps,
Barry
#13 rawky
rawky
  • 419 posts
Posted 01 July 2011 - 06:05 PM
Hope This Helps,
Barry
It would seem it has this high point you're talking about, but it only happens on one side? It takes a good amount of force to get it past this high point!
I haven't run it very far no, but this new symptom of the wheel clicking at speed concerns me, any ideas?
It's just passed MOT with no play in the wheel bearings!
#14 rawky
rawky
  • 419 posts
Posted 02 July 2011 - 05:10 PM
Amazing car, it seems to have fixed itself. Maybe the high spot has just worn down?
The ticking noise was caused by slack in the handbrake mechanism allowing the linings to hit the backplate as I drove along. Really loud clack clack clack noise has now gone!
#15 Ben1400
Ben1400
  • 40 posts
Posted 04 July 2011 - 08:50 AM
Hi,
Yes it could have worn the high spot down, it doesn't take many miles.
Slack in the handbrake cables/mechanism should not cause your brake shoes to rattle against the back plate. If it was me I would have the brakes apart to check they have not been reassembled incorrectly/have springs missing or broke.
I assume you have tightened the handbrake cable up and the noise has stopped happening now. I believe that this is only masking the real problem. Compare the shoe/spring/handbrake lever arrangement with the manual diagrams. This sounds very dodgy to me!!!!
If you are unsure at all, take it to a garage/quick fit sort of place. Brake failure is no fun!
Regards,
Barry
Edited by Ben1400, 04 July 2011 - 08:56 AM.
