Posted 26 February 2011 - 07:18 PM
Posted 27 February 2011 - 01:08 PM
Posted 27 February 2011 - 01:16 PM
Posted 27 February 2011 - 01:35 PM
Posted 27 February 2011 - 02:20 PM
no I didn't use rubber grease at the time only brake fluidWhen you re-built did you use rubber grease?
It's great at helping to keep the moisture out of the space behind the rubber and it will help the rubber seals by reudcing the wear against moving parts.
Posted 27 February 2011 - 02:24 PM
casing is fine just surface rust but this one locks up could it be the internals breaking down (didn't split them apart) just new pistons and sealsIf the casting is undamaged rebuild them again.
Posted 27 February 2011 - 07:13 PM
Posted 27 February 2011 - 07:58 PM
Posted 27 February 2011 - 08:26 PM
Posted 27 February 2011 - 09:58 PM
