Arc Vs Mig Welding
6 replies to this topic
#1 shed
shed
  • 594 posts
Posted 27 February 2011 - 04:51 PM
hi
toying with the idea of getting a welder for playing with a subframe (for 16v). even if i could tack bits in place securely and take to someone to finish it off, which would be easiest to use?
#2 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 27 February 2011 - 05:12 PM
mig is lot easier, esp for thinner stuff.
#3 charie t
charie t
  • 3,153 posts
Posted 27 February 2011 - 05:42 PM
hi
Mig is definately easier to grasp, but if you are tacking it together, why not finish it yourself and weld it completely?
#4 shed
shed
  • 594 posts
Posted 27 February 2011 - 05:50 PM
never welded before, id hate the frame to drop to bits as i chug along down the road =]
just thought arc is cheaper for playing with, im gonna be down the garden with it rather than in a garage and hear the gasless migs arnt as good as gas
#5 Tupers
Tupers
  • 4,158 posts
Posted 27 February 2011 - 06:01 PM
Definitely buy a Mig and a bottle of Argon shield light gas.
The only thing Arcs are good for nowadays is welder RSJs on building sites.
#6 charie t
charie t
  • 3,153 posts
Posted 27 February 2011 - 06:41 PM
Practice, practice practice. Take up an evening course and it will save you a fortune in the future.
You can weld with a gas mig outside. Just on a windy day makes it more awkward, so put a screen up
Gasless is ok to weld with but it takes practice again.
#7 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 27 February 2011 - 08:00 PM
Actually with practise you can get better welds with an ARC welder than with a MIG, I learnt with an ARC and when I got to use MIG it was easy peasy, being thrown in at the deep end pays!
Whilst ARC is definitely harder, it the OP has never welded before- a stick welder would probably guarentee better penetration, I see so many amateur welders doing what they think is a good job and it just looks like bird poop sitting on the top and would come off with a knock! MIG allows you to weld without penetrating, ARC is more likely to get a more structural weld IMO- if you have a £50 welder of each type, the MIG will struggle to weld nicely but the ARC would do 1/2" thick stuff!
Once you know how to really weld a MIG is so quick and easy to get good welds but I think with cheap low power machines and amateurs it is different.
