Bucket Seats Rock Slightly, Mot Fail?
Posted 27 February 2011 - 07:47 PM
someone told me today that they would fail the mot on this?
is this true?
Posted 27 February 2011 - 07:49 PM
Posted 27 February 2011 - 07:52 PM
do you know why this is a fail?
i know a moving seat isnt the greatest but its only an inch hmmmmmm
Posted 27 February 2011 - 07:58 PM
However. Ive had it like that for about 3 years and its never been pulled up before. But it is a fail.
Edited by redhotminilewis, 27 February 2011 - 08:00 PM.
Posted 27 February 2011 - 08:01 PM
Its an insecure seat but the tester will use his discression. Ideally it shouldn't move at all, but the original mini locking design was not the best.oh! i was hoping he was lying because hes usually full of s**t. may have to bend the bar the arm catches onto to it locks down lower.
If you place some wood under the seat base so the seat can sit higher and move less, and it will pass. Best to look into a better way but to get you a green ticket
Posted 27 February 2011 - 08:02 PM
truthfully i do drive like a prat most of the time and i do brake quite late and ive never felt my seat move whilst im in it.....suppose it would be diffrent if i went into the back of a lorry or something
how did you solve yours?
ive got a back seat and it does get used, so i do kinder need my seat to move forward so welding it isnt really an option.
Posted 27 February 2011 - 08:03 PM
Posted 27 February 2011 - 08:04 PM
Dependant on the original design. A morris minor never had a way of securing the seat base throughout production. Earlier models even had very helpful fold down backs too, which really helped you become disfigured.Mine moved about have an inch and it failed. Its a fail because if theres play in the seat then its likely, after time the holding mechanism will get damaged and possibly perish and if your in an accident with a seat thats not secure, you go forward because of momentum and so does the seat. Sort of like a sandwich between the seatbelt, you and the seat.
Posted 27 February 2011 - 08:06 PM
mine are bucket seats mounted onto the orignal sliders and locking bars
will this make a diffrence to mr mot man?
Yes, again down to the testers discretion. If he thinks it is inadequately secured, it will failmy passenger seat does the same aswell, so that would come under a fail the same as the driver im guessing?
Posted 27 February 2011 - 08:13 PM
i also had this problem and i put blocks of mdf under my subframes, worked a treat
Posted 27 February 2011 - 08:17 PM
Posted 27 February 2011 - 08:29 PM
how does the blocks of mdf work? was that a quick fix to pass mot or a permanent fixture?
literally a quick fix to get it through
basically my subframe was too small and quite low, it sat underneath my subframe pushing it up
Posted 27 February 2011 - 08:31 PM
Posted 27 February 2011 - 08:35 PM
I said that further upoh ok, thats just give me an idea to stop mine rocking, slide some wood through the locking bars so it dont rock.....hopefully the mot man dont notice
Sit it on the carpet, double sided sticky tape it won't move, and will be fine for mot man too
