hi guys just wonted to ask if you think i will need a return fuel pipe to my petrol tank from a fuel regulator? ive got a avonbar turbo engine and twin cooper s tanks with no return fuel pipe. im not 100% sure if i need a return line or not? what do you think? cheers dave
Return Fuel Line Need Or Not
davetherave1985
, Feb 27 2011 09:26 PM
4 replies to this topic
Posted 27 February 2011 - 09:26 PM
Posted 27 February 2011 - 09:42 PM
I think alot of the turbo guys either mod the tanks for a return line, or use a T piece and return the fuel to the low pressure side of the pump.
Posted 27 February 2011 - 09:44 PM
If your running a regulator then yes you will need a return as well as some inlet into one of the tanks. What fuel pump are you using?
Posted 27 February 2011 - 10:58 PM
hi stu im using a metro turbo fuel pump my mate who is s mechanic said i can use a regulator with no return just in and out but im unsure.
Posted 28 February 2011 - 12:33 AM
Roller vane pumps, as used on injection systems & the Metty turbo must have a return. You can damage the pump by running it without a return (though newer pumps have an internal protection valve & just don't pump). As said, the easiest is to put a Tee in the line from the tank to the pump - or get hold of an injection Mini tank.
