Slam Panel - Making It Removable?
Posted 27 February 2011 - 10:09 PM
Posted 27 February 2011 - 10:16 PM
Its going to need bolting, and/or some sort of braceim thinking of cutting my slam panel out, and making it removable, whats peoples opinions? And how would/have people done it? Many thanks, sam.
What is wrong with a removable grill?
Posted 27 February 2011 - 10:20 PM
Posted 27 February 2011 - 10:21 PM
Posted 27 February 2011 - 10:24 PM
Not sure what you mean by replace it with box. The wings will be flapping, well like wings.i just think it gets in the way, is it structural? So what if i were to replace it with a removable bit of box section?
The front of the subframe bolts to the front panel, so brace bars will be needed.
Posted 27 February 2011 - 10:25 PM
The '90s so-called Works rally cars had removeable slam panels. Cut it at both ends and insert a doubler folded to slip inside the channel shape. Weld this to the body end and slip the slam panel over it. Match drill through the panel and doubler in the removable section and use push pins or similar to secure it.
kind of what i was thinking of doing, what do you mean by a double folded? I guess you mean like a tag type thing for it to bolt to? Thanks.
Posted 27 February 2011 - 10:52 PM
Posted 27 February 2011 - 11:15 PM
The slam panel itself is U-shaped and when you cut it out it appears quite flimsy. So I welded pieces to it in four places to create short box sections which stiffened it up considerably. You also need to weld some ears onto the slam panel ends (sticking downwards) to mate up with those on the body. I secure the panel to the body with three nuts/bolts each side though two would suffice. The BMC stiffening strip is unboltable at the bottom. The result is a panel which is alot firmer than before. All the work was done before a re-spray.
Posted 27 February 2011 - 11:20 PM
Posted 28 February 2011 - 09:28 AM
Posted 28 February 2011 - 10:01 AM
Posted 28 February 2011 - 10:25 AM
what about fitting fibreglass removable front?
i dont like them, lol.
Posted 28 February 2011 - 10:38 AM
