Mot Failure
Posted 28 February 2011 - 10:01 AM
Rover MINI Rio
1993
Excessive play in ball joint MOT failure
Posted 28 February 2011 - 10:05 AM
The ones top and bottom of the hub assy, These can be adjusted by use of shims, but may need replacing depending how bad.
The cup and ball that connects the trumpet to the top arm, The plastic cups wear out but a cup and ball is only a couple of quid
The rear is just a cup and ball on the radius arm to trumpet joint.same here plastic cups wear.
Edited by lrostoke, 28 February 2011 - 10:07 AM.
Posted 28 February 2011 - 10:08 AM
Posted 28 February 2011 - 10:10 AM
Posted 28 February 2011 - 10:16 AM
Posted 28 February 2011 - 12:48 PM
Posted 28 February 2011 - 01:09 PM
Your specialist may have fitted new top and bottom ball joints and set them up perfectly but if they didn't lap them in then the joints can be expected to only last about this long before needing adjustment. The knuckles (plastic cup type joints) aren't really counted as ball joints (although that is what they are) and would never show up on the MOT as worn because they are always under spring load and so always appear tight. They are not subject to the MOT anyway. The only joints that would be tested are the top and bottom ball joints connecting the suspension arms to the hub and the steering track rod end. The rear suspension doesn't use any ball joints that would be tested.
Spot on very useful info... thank you, its going in early tomorrow so i will be sure to report back, im still very pleased its the first MOT since i have had it and its done very well, just looking forward to getting it back on the road.
