Reverse Drive Forward ?
14 replies to this topic
#1 markyzee
markyzee
  • 179 posts
  • Local Club: Hell Yeah: CV1 Minis
Posted 28 February 2011 - 11:32 AM
Just rebuilt my engine , didn't touch the gear box. And now when I put it in reverse it drives forward.
Would it just be the linkage?????
And how do I solve it???
Cheers mark
#2 CLASSIC-MINI-BITS
CLASSIC-MINI-BITS
  • 493 posts
  • Local Club: LCMOC.COM
Posted 28 February 2011 - 11:44 AM
Cheers mark
does the linkage feel light / sloppy as if it is not doing anything? it is usually one of the roll pins inside the alloy housing that has dropped out or it has cracked away. twist off the gear selector lever and take a look inside it the front pin (with luck) will be missing, if it is replace it with a new one or it will drop out again.
Edited by CLASSIC-MINI-BITS, 28 February 2011 - 11:46 AM.
#3 markyzee
markyzee
  • 179 posts
Posted 28 February 2011 - 11:58 AM
No it's not that, I put that in last nite. No it feels normal and drops into reverse.
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 28 February 2011 - 12:03 PM
What happens when you put it into 1st? Does it pull away like its in 4th when you put it into reverse?
Edited by Carlos W, 28 February 2011 - 12:04 PM.
#5 MRA
MRA
  • 7,607 posts
Posted 28 February 2011 - 12:06 PM
Is it manual or automatic..... if it is automatic then your sprag clutch has flipped ;)
If manual, di dyou strip the gear lever mechanism..... you could have put the "bellcrank" up side down ;)
#6 markyzee
markyzee
  • 179 posts
Posted 28 February 2011 - 12:28 PM
Yeah it pulls of *******, that maybe be the problem, cheers fella i'l have a go tonite and report back
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
As above, which way up was the rod eye when you put the gear stick back in last night?
#8 markyzee
markyzee
  • 179 posts
Posted 28 February 2011 - 01:40 PM
The domed end is pointing up I think . I looked at the pic in the Haynes manual but I may have put it the wrong way as I was looking upwards at it.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 February 2011 - 03:06 PM
Yeah that'll be it, the eye should be at the bottom of the housing.
#10 markyzee
markyzee
  • 179 posts
Posted 28 February 2011 - 03:35 PM
Cheers buddy . Starting get worried that I broke the gear box somehow and gonna have to strip it again
#11 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 28 February 2011 - 03:48 PM
Maybe the engine is in back to front? ;)
#12 markyzee
markyzee
  • 179 posts
Posted 28 February 2011 - 03:51 PM
I'm am the backwards man the backwards man.
#13 1984mini25
1984mini25
  • 8,785 posts
Posted 28 February 2011 - 04:07 PM
You are lifting the gearstick at the same time, instead of just seleticng 4th?
#14 markyzee
markyzee
  • 179 posts
Posted 28 February 2011 - 04:09 PM
Yep
#15 markyzee
markyzee
  • 179 posts
Posted 28 February 2011 - 09:44 PM
Just to let you know it was the wrong way round. But took it for a spin and my frickin head gasket blown . You got love these annoying little cars. Ggggrrrrdrrr
