Yellow Tag And Black Tag Master Cylinders
7 replies to this topic
#1 Broomer
Broomer
  • 1,771 posts
Posted 28 February 2011 - 06:10 PM
right chaps.
im at the stage of sorting the brakes on my K series Mini. servos been ditched for obvious reasons. i have 2 black tag master cylinders, but i could do with something a little more compact, and am i right in thinking the yellow tag is alot slimmer?
is there any difference in bore sizes / performance between the two masters?
also do i ditch the standard bias valve on the bulk head and run an adjustable one, or is the standard item upto the job?
#2 Broomer
Broomer
  • 1,771 posts
Posted 01 March 2011 - 10:50 AM
Bump.
#3 Ethel
  • 26,183 posts
Posted 01 March 2011 - 12:55 PM
The FAM7821 will do the job, but you can swap it if needs be.
The yellow tag GMC227 is a bit slimmer, but I can't see it making any difference. The horizontal master has the biggest bore. GMC227 is the same bore as GMC167 on top but bigger in the bottom. It has a M12x1 thread to stop it being connected wrongly - the bottom outlet must go to the rear brakes.
#4 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,231 posts
  • Name: Simon Jackson
Plus repair kits are more readily available for the yellow band, so that would be my choice....
#5 Broomer
Broomer
  • 1,771 posts
Posted 01 March 2011 - 01:20 PM
Ideal chaps. I'll use the black tag for the time being even though I need to tilt it backwards several degrees and remove some material from beside the union mounting hole to clear my inlet manifold.
And switch to a yellow tag at a later date.
So the regulator on a 1988 servod mini is ok to use also ?
#6 Ethel
  • 26,183 posts
Posted 01 March 2011 - 01:32 PM
It's the same regulator. I'd be wary if the clearances are that close - what happens when the engine is rocking against the stabilisers?
Post a piccy, maybe someone will see an alternative solution. Can you tilt the engine a bit, or spacer the pedal box back in to the car slightly? Have you seen Big Chief's Micra conversions, some good lateral thinking (literally) there.
#7 ado15
ado15
  • 614 posts
Posted 01 March 2011 - 06:27 PM
You may struggle to get the black tag cylinder to bleed properly after it's been totally dry. It had a design fault which is why Lockheed replaced it with the yellow tag one.
#8 Broomer
Broomer
  • 1,771 posts
Posted 02 March 2011 - 09:34 PM
no clear pictures of the clearance issue.
one quick question.
whats a green tag master?
