Car Pulling To The Left
Posted 01 March 2011 - 05:44 PM
hi,
i had the tracking done when i got it and this helped but it has got worse and worse recently, on some roads it really really pulls! i think the suspension cones need changing as the car is a bit low at the front but surely this wont cause it to just pull to the left and only on some uneven roads.
i have checked the tie rods etc and everything seems secure.
the front left wheel does look like it towing out ever so slightly, any help much appriciated!
thanks in advance!
or if anyone is local i will pay petrol and beer money if your free to have a look/take it out and see for yourself!
Posted 01 March 2011 - 05:48 PM
1998 Rover Mini Cooper Sportspack - STANDARD
There may be your answer
Posted 01 March 2011 - 05:52 PM
Posted 01 March 2011 - 06:01 PM
yeh but it is so slight comapred to the pulling of the car and i think i am only noticing it as i am looking for a prob, if that make sense
Posted 01 March 2011 - 06:02 PM
Posted 01 March 2011 - 06:04 PM
Dunlop ones were the worst.
Agreed; the standard dunlop sport sp 2000 / 2500 tramline like a b....
A539 reduce the affect, and very good tyre. But suspension / tracking should be checked prior to spending out on 4 new tyres...
Edited by L400RAS, 01 March 2011 - 06:05 PM.
Posted 01 March 2011 - 06:05 PM
yeh i know that it will pull due to the large wheels etc but it has just got worse over the last week or so!
Posted 01 March 2011 - 06:06 PM
Are you driving the same roads / roads you know the car has never pulled on before? if so, something has changed in the setup then, suspect tracking. Hit any bumps / kerb etc?yeh i know that it will pull due to the large wheels etc but it has just got worse over the last week or so!
Edited by L400RAS, 01 March 2011 - 06:07 PM.
Posted 01 March 2011 - 06:08 PM
but yeh, ame roads and i have noticed a big difference
Posted 01 March 2011 - 06:09 PM
- the wide tyres
- excessive road wear.
- The weight of you as a driver stressing an already stressed and old rubber cone, on teh drivers side
- unequal tyre pressure
- Binding brakes
- wheels need rebalanced after dropping a weight
- May even be the rear wheels
Posted 01 March 2011 - 06:17 PM
Posted 02 March 2011 - 12:44 PM
okay, thanks for all the help guys so far
much appriciated
Bent a tie bar during a jacking up or a little accident?
Posted 21 April 2011 - 10:24 PM
steering rack was slightly loose! so tightened that up too, drove car a still feels like its dragging/tramlining however the tracking obviously needs doing after the cone change and steering rack sorted, so basically am leaving it for a few more days for cones to settle then will get car tracked again, so hopefully will feel better after that (i hope!)
Posted 22 April 2011 - 08:14 PM
