Anti Run On Valve.
11 replies to this topic
#1 starletman
starletman
  • 249 posts
Posted 03 March 2011 - 05:51 PM
Does anyone have an anti run onvalve fitted and do they work.I have seen one in this months Mini World (page 52) and was considering getting one.Would like some opinions and possible alternatives as i do not like stalling the car in gear or flooding with fuel when turning the ignition off,
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 03 March 2011 - 06:11 PM
rover fitted them to the coopers
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 March 2011 - 06:48 PM
Cars should only be fitted with them if the running on is not caused by a fault. Most cars that run on do so because they are out of tune or otherwise broken. Very few Minis have a designed state of tune that will lead to running on, largely because running on only happens when something is overheating in the combustion chamber which is not great.
#4 mab01uk
mab01uk
  • 12,575 posts
Posted 03 March 2011 - 08:04 PM
As said they were fitted to Rover Coopers bolted to the servo bracket, I use one with success on my Mini which is the same type as in Miniworld and was bought from a breakers very cheaply when taken from an A-Series engined Metro (only fitted to 1275 as standard I think). I believe they were originally factory fitted as the later carb 1275 A-Series was prone to running on due to lower emissions requiring running at leaner mixtures and unleaded petrol.
Edited by mab01uk, 03 March 2011 - 08:05 PM.
#5 starletman
starletman
  • 249 posts
Posted 03 March 2011 - 08:33 PM
My car does have a 10.5cr,i have read this is a common problem with high compression engines.
#6 Dans
Dans
  • 69 posts
Posted 04 March 2011 - 01:57 PM
I'd never heard of these before I read this months miniworld. I think its exactly what I need as my overrun annoys me quite a bit! (I have a properly setup high compression engine).
Does anybody know if similar valves can be bought elsewhere? as £70 is a bit steep!
#7 Ethel
  • 26,112 posts
Posted 04 March 2011 - 02:52 PM
Other cars use the same valve.
There are 2 possible approaches...
Either, introduce more air in to the manifold (bypassing the carb), like the Cooper one - any decent sized solenoid valve would do, like an idle air valve off an injection car.
Or, apply some suction to the fuel float chamber to stop the fuel being sucked through the jet. It may even work the other way round: if you enrich the mixture. This is a bit trickier to do, especially if you're using a HS carb, some HIF's already have the suction ports in place for part throttle weakening.
#8 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 04 March 2011 - 04:12 PM
ive bought one for 3 pounds ;)
local motor factors should have them in stock
freaker
#9 danrock101
danrock101
  • 2,478 posts
Posted 04 March 2011 - 04:22 PM
or take off the head and give it a good decoke usually helps, using decent fuel like shell can help too
#10 mab01uk
mab01uk
  • 12,575 posts
Posted 04 March 2011 - 07:34 PM
Before I fitted a Metro anti-run on valve I used to let the engine idle for a minute and just before finally switching engine off, pull the choke out to full on, this has a cooling effect and stopped the run-on most times. If I forgot to do this, switching off immediately, especially after a hard run usually resulted in running on which is not good for your bearings.
http://www.somerford.....201969 On.pdf
http://www.moss-euro...amp;SortOrder=1
Fitting:
http://www.moss-euro...ons/STN127Z.pdf
Edited by mab01uk, 04 March 2011 - 07:42 PM.
#11 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 06 March 2011 - 08:09 AM
my car runs on when using 91-95 RON fuel.. on 98, no issues what so ever..
when i do use cheap fuel and it does run on, I just put it in 2nd gear and gently release the clutch, forcing the engine to stall.
#12 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 06 March 2011 - 12:47 PM
why second?
