How To Protect Behind Seals In Calipers
Posted 04 March 2011 - 08:21 PM
Posted 04 March 2011 - 08:25 PM
Posted 04 March 2011 - 08:29 PM
http://en.wikipedia....wiki/Hygroscopy
Posted 05 March 2011 - 09:10 AM
Posted 05 March 2011 - 06:58 PM
It will be used for racing so running on DOT 5, opinions vary on change interval for DOT5 when racing, some say never, some once a season (sounds better)Change your brake fluid frequently, 2 years maximum.
You can use the special grease.
Topic
http://www.theminifo...p;#entry2065282
Do you know if the stuff mentioned is Hellerine oil? I have a big bottle of that but wasn't sure if its compatible with brake systems (blooming great for fitting windows though!)
Posted 05 March 2011 - 07:27 PM
If you are running DOT-5 and you have cleaned these bores up, you should not see any further rust. As a footnote, most racers I know will not run DOT-5 on the track.
Posted 05 March 2011 - 07:32 PM
I've not encountered Hellerine oil, but I would say the rubber grease is very thick and so stays where you put it, would oil not slowly move away?Do you know if the stuff mentioned is Hellerine oil? I have a big bottle of that but wasn't sure if its compatible with brake systems (blooming great for fitting windows though!)
Posted 05 March 2011 - 07:35 PM
Posted 05 March 2011 - 09:14 PM
If you intend to use DOT 5 you won't get any rusting as said above, DOT 5 is hygrophobic. It repels water rather than absorbing it. I assume you are aware it is completely incompatible with mineral brake fluids and you must very thoroughly flush through the system if it's ever had mineral fluid in it. Some advise stripping and cleaning all the components and rebuilding them using a silicone rather than mineral fluid as an assembly lubricant. You should still replace the fuild regularly though because while it repels water, DOT 5 absorbs air which can give a spongy pedal that no amount of bleeding will improve. It can also trap pockets of water around the system because it won't absorb any.
Are you certain you don't mean DOT 5.1?
Posted 06 March 2011 - 10:09 AM
If it's the "wet" side of the piston seal, in other words inside the hydraulics of the calliper, then grease would be unnecessary and ineffective, and the brake fluid changed at the required interval should be sufficient to minimise rust.
