7.5" 's' Brakes Compared To 8.4"
Posted 05 March 2011 - 12:24 PM
Now logic would say that the 7.5" setup isn't going to be as good as the 8.4" but how much difference is there between the 2?
Posted 05 March 2011 - 12:40 PM
ashley
Posted 05 March 2011 - 04:07 PM
Posted 05 March 2011 - 04:23 PM
Actually that's not so glib. The braking effect is tied to the leverage of the disc & 8.4's have 0.9/7.5 more, or 12%.
7.5's do close the gap with pad area, and the average leverage (to the centre of the pads) will be somewhat less.
Posted 05 March 2011 - 04:34 PM
Edited by Cater_Racer, 05 March 2011 - 04:35 PM.
Posted 05 March 2011 - 04:48 PM
Halve that, the braking leverage is based on the disc radius not diameter. By the time the shape of the pads and offset of the caliper is taken into accout, I'd be surprised if there was much more than 4% difference.
Posted 05 March 2011 - 07:47 PM
Posted 05 March 2011 - 09:08 PM
Posted 05 March 2011 - 09:14 PM
Posted 06 March 2011 - 08:47 AM
Posted 06 March 2011 - 09:39 AM
Posted 12 March 2011 - 08:24 PM
The simple formula, has a lot to do with .....
Clamping pressure, mean radius, number of pads/discs (mini = 2 as it has a single disc per corner) friction coefficient of the pad material, and pad swept area.
You are also using stlightly smaller diameter wheels and tyres, therefore the ratio of disc mean radius against tyre radius when measured to the road will possibly offset any disadvantage that your 7.5" disc brake setup will give you
Posted 12 March 2011 - 08:49 PM
Posted 13 March 2011 - 07:32 PM
comparison of the diameter against the radius is going to exactly the same
Yes I had it in my head that the calculation above was comparing the diameter of one to the radius of the other but looking again I don't think it is.
Concerns have been raised over anyone saying that any given set of brakes are fine, without knowing much about the installation and use in question.
Lets limit it to saying that S brakes, when fitted properly and plumbed correctly using appropriately sized wheels and tyres are adequate to brake the mass of a standard Mini. Whether they are the right choice for your particular installation is a lot more complex a question.
Incidentally there are other options for fitting 10" rims. Personally I dislike the Fiesta caliper or massive spacer route (including the spaced wheels available that sit next to the brake rather then over it). You can use 8.4" discs turned down to 7.9" or 7.75" though, many companies make very good 4 pot alloy calipers for these sizes.
