How To Fit A Electronic Flasher Unit
Posted 05 March 2011 - 03:44 PM
Stuart
Posted 05 March 2011 - 04:19 PM
Posted 05 March 2011 - 04:38 PM
Posted 05 March 2011 - 04:42 PM
Posted 05 March 2011 - 04:47 PM
Grab a 3 pin flasher relay (fiesta or any mid 90's ford i use as there are hundreds in the scrappy and they can drive hazards or just indicators)
Make an earth wire to a good earthing point and put it on terminal 31
With a test lamp (or multimeter) switch the ignition on and find the permanant live to your current flasher relay, connect to pin 49
Then the other wire connect it to the remaining pin 49a
Test them and smile at them working nicely, before you hide it away neatly. Some electrical tape around the wires isn't a bad thing either
Its the same process for the hazard flasher unit too using another fiesta relay
Edited by charie t, 05 March 2011 - 04:48 PM.
Posted 05 March 2011 - 05:09 PM
Simple 5 minute job that makes such a difference. I did 2 mates cars last night.
something like this
http://cgi.ebay.co.u...=item3f07d80def
Posted 05 March 2011 - 05:13 PM
I'm going to local parts people in a moment, so i'll find out how much they charge
Posted 13 March 2011 - 01:36 PM
Yes
, but
i get mine free. Scrap man isn't interested in them.
iv got the flasher unit and fited and its sooo much better makes thanks for the help
Posted 13 March 2011 - 02:03 PM
Posted 13 March 2011 - 02:27 PM
Edited by greensilver mini, 13 March 2011 - 02:32 PM.
Posted 16 January 2012 - 11:17 PM
Does anyone have a part number?
Paul
Posted 17 July 2012 - 09:16 PM
Both my hazards and indicators were running almost twice as fast as they should. So popped into Halfords this evening and bought two electronic three pins units. Got home and thanks to Charie's guide above, had them both fitted in less than half an hour. Most of that time was setting up a nice clean new earth under the dash.
Not only are both the hazards and indicators now flashing at a more relaxed speed, they even seem a little brighter. Best bit is a nice audible click too, old ones were silent.
So, nice easy job to do and sorted an issue that has been an advisory on the last two MOTs (I've only had the car two weeks).
So thanks for the posts above everyone.
Ian
