Clutch Pedal Seized Onto The Bar
Posted 05 March 2011 - 07:06 PM
I RECENTLY NOTICED THAT MY MINI THATS BEEN STOOD FOR 3 YEARS HAD SEIZED ON THE PEDALS.
TO BE EXACT IT IS THE CLUTCH PEDAL THAT IS SEIZED TO THE BAR THAT THE PEDALS ARE SUPPORTED ON, WHILST THE BRAKE PEDAL MOVES FREELY. I HAVE FOLLOWED THE HAYNES MANUAL BUT WHEN IT CAME TO SLIDING THE BAR OUT IT IS STUCK SOLID. I TRIED TO FREE IT WITH A LITTLE PERSUASION BUT ENDED UP JUST WRECKING THE END OF THE BAR (SO I HAVE HAD TO CUT OFF THE END AS IT WOULD NOT FIT THROUGH THE MOUNTING IF I HAD GOT IT FREE!
MY ONLY IDEA IS TO CUT THE BAR BETWEEN THE PEDALS AND AT THE LEFT OF THE CLUTCH- BASICALLY REMOVING BOTH PEDALS FROM THE PEDAL BOX. THEN I WOULD NEED TO FIND A REPLACEMENT CLUTCH PEDAL AND THE PEDAL BAR? (OR WOULD ANY BAR OF SUITABLE LENGTH DO?) AND WOULD I BE ABLE TO DRILL/ PUNCH OUT THE BAR WHICH IS STUCK IN THE CLUTCH PEDAL?
PLEASE HELP AS THIS IS THE WORSE JOB I HAVE EVER COME ACROSS ON MY MINI AND IM WELL AND TRULEY STUCK!!! THANKS!!!
Posted 05 March 2011 - 07:43 PM
A car stood for 3 years typically will seize the clutch, not the pedal. To test if it is really the clutch pedal - unbolt the slave cylinder from the bell housing, and GENTLY push the clutch pedal. If the pedal goes very light, and moves to the floor, its the actual clutch / clutch arm that has seized. Try penetrating oil in the plunger / clevis pins etc, then lever the clutch arm to free it off, otherwise just try starting it and bumping the clutch off. Please note, you should give the car a serious service after standing that amount of time. And once new oil is in there, crank it over without the spark plugs in to check that the oil light goes out / engine has oil pressure before even attempting to get the car running with FRESH petrol.
P.S. PLEASE DONT USE FULL CAPS IN FUTURE...
Edited by L400RAS, 05 March 2011 - 07:45 PM.
Posted 05 March 2011 - 07:52 PM
Posted 05 March 2011 - 09:20 PM
Posted 05 March 2011 - 09:28 PM
but it si not the clutch that is seized as i can engage/disengage gears.
That means nothing if the engine isn't running.
The pedal shaft can't turn in it's housing, it has a peg at the inboard end that restrains it. That would have to have sheared or disengaged before the shaft could rotate. Are you sure it's turning? It's extremely unlikely that a bronze bush has corroded that tightly onto a steel shaft in a protected environment, in 3 years.
Posted 05 March 2011 - 09:45 PM
I started him up then went to press the clutch. It pressed in very hard once, come back out then it was stuck solid.
After panicking because the mot was booked in for 9.30 and it was already that time we looked around the clutch and decided it was the bar that was going in the clutch that was seized. After lots of the old wd40 and some knocking with a bar it finally released. Just managed to get to the mot 30mins late but they still did it and he passed
So i would of thought this is your problem, I wouldnt of thought it would be to do with the pedals rusting, I might be wrong though. As been suggested i would do a couple of days soaking the pedal bar and clutch bar with WD40
Posted 05 March 2011 - 10:14 PM
I think i must have had a leak that has dripped onto the pedal shaft whilst stood as its covered in rust around the pedals!
Edited by roderick gregg mini, 05 March 2011 - 10:16 PM.
Posted 05 March 2011 - 10:43 PM
Posted 05 March 2011 - 11:31 PM
