1988 Mini City E Vin Number Location
6 replies to this topic
#1 utterchaos
utterchaos
  • 15 posts
Posted 07 March 2011 - 05:24 PM
hi i have got a 1988 mini city 1000e, i have the vin number and the reg number, but it is cat c so needs to have a vic check done, the problem is that there is no vin plate under the boot just two rivet holes where it should be, where on this car should i find the vin number, there are some numbers in the scuttle plate rain channel and the ones i can make out so match part of the VIN i have been given, but i cannot make the full number out, will i have to remove the paint to enable me to vies it, the engin number matches as well, but i dont have th v5 was sent to re register the car i did not know it tas cat c but its only a damaged wpanel above rear drivers wheel.
where else can i check on the car for the VIN is it hiding anywhere else that the VIC people can find so i can get it passed
cheers
#2 1990minicity
1990minicity
  • 54 posts
Posted 07 March 2011 - 06:13 PM
under the Bonnet it should be stamped in the 'water run off area' round the engine bay.
#3 utterchaos
utterchaos
  • 15 posts
Posted 07 March 2011 - 11:14 PM
will have to check, so there is only three places
1, vin plate (missing)
2, Scuttle plate (can just make out some numbers)
3, under bonnet water drains, or is that the scuttle plate bit
is there no where else that can be checked to make sure the car and engine match so i can get the car registered again once the work has been finished
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 March 2011 - 11:18 PM
Yes the post above is referring to the scuttle gutter, that's the only place it's stamped. Your car must have a VIN plate as well, it's a legal requirement and you shouldn't be able to pass a VIC without one. Get a new one properly reverse stamped, it's perfectly legal providing you aren't comitting fraud.
#5 utterchaos
utterchaos
  • 15 posts
Posted 08 March 2011 - 12:47 AM
Where can you get them from? I new to all this stuff normally buy cars new from main dealers but not possible for an old mini,
and i dont have a v5 as its kept because of the cat c bit
Edited by utterchaos, 08 March 2011 - 12:56 AM.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 March 2011 - 10:51 PM
I think Mini Mail do them, you will need to prove that you own the vehicle in question though which is tough without documents. Although a V5 doesn't prove title anyway, do you have a receipt?
#7 utterchaos
utterchaos
  • 15 posts
Posted 10 March 2011 - 01:15 AM
yea i have a recipt from the item
