Year: 1993
The car to the best of my knowledge was originally a SPI, engine block is, and i'm going on the assumption that the loom is aswell due to having the 'extra' relays near the wiper motor.. (See picture) Can someone confirm that this is an SPI loom or not? From this picture atleast..
Basically before I go chasing wires, which wiring diagrams should I be looking at in the haynes manual? Injection models or carb after 88'?
So now, my issues..
Brake lights not working at all, indicators, horn, main beam (flash only), interior light, rear windscreen heater are very intermittent..
So I've found that the fusebox is wired extremely arse about face..
Am I right in thinking that the way the fuses are labelled in the haynes as in 1 one end and 2 the other means its the top fuses 1 being the connection on the left and 2 on the right? If thats right what about the fuses that just have one number? Are they the inline ones?
so far from reading the haynes i've come up with this layout.. Although off the top of my head I only remember having two red and two purple wires, but many more doubled up and in the 'wrong' place..
The green wire from the top fuses that controls the reverse lights, brake lights and rear windscreen heater where does this physically dissapear to after the fuse box? Other than the brake switch, which to add to the confusion definitely has the wrong colour wires on my car.. Neither side has a green on its own, and the other side is either black, or very dark purple..
Everything has worked previously, just not brilliantly! I haven't phsyically changed anything so i'd imagine something is shorting..
