Steel Gauges/ Thicknesses.
7 replies to this topic
#1 Moke boy
Moke boy
  • 74 posts
Posted 09 March 2011 - 01:21 PM
Just secured a MIG welder and hope to start practicing after a 20 year gap.
Can anyone confirm what the general steel thicknesses are on the structural elements and body panels.
Many thanks
#2 Rich.
Rich.
  • 520 posts
Posted 09 March 2011 - 01:47 PM
I use 1.2 (18 guage)
Rich
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,057 posts
  • Name: Neil
Posted 09 March 2011 - 06:31 PM
1.2 mm is found on the bulkhead cross member and rear heel board. 0.9mm is used virtually everywhere else on the shell. If you try to use 1.2mm thick steel on the floor it will not sit flush on one side. It does not matter if its somewhere that you don't see the other side.
It all depends on what sort of finish you are going for really, for me as i'm building the car back to original spec then i use the right thickness in the areas needed. Its personal choice really.
#4 Rich.
Rich.
  • 520 posts
Posted 10 March 2011 - 09:29 PM
Yer i read it wrong, thought you were asking purely about structural.
20 guage for general body, 18 for structural. Alhough with it being a monocoque its all structral, but thats a topic fo a different day :)
Rich
#5 nightroamer
nightroamer
  • 246 posts
Posted 11 March 2011 - 02:34 PM
Guys i could only get 0.8mm or 1.0mm from my local supplier so i went for 1.0mm.
Will this sit ok if im but welding it in?
#6 R1mini
R1mini
  • 1,387 posts
Posted 11 March 2011 - 04:18 PM
1mm is the metric equivalent of 20 swg these days, I find this works well on the mini panels. It will be fine to butt weld 1mm into the mini
David
#7 Moke boy
Moke boy
  • 74 posts
Posted 13 March 2011 - 05:43 PM
Thanks Guys.
#8 100ev8
100ev8
  • 622 posts
Posted 13 March 2011 - 07:15 PM
columns dont line up but im sure you get the idea
Gauge No Inch MM
0 0.324" 8.230mm
1 0.300" 7.620mm
2 0.276" 7.010mm
3 0.252" 6.401mm
4 0.232" 5.893mm
5 0.212" 5.385mm
6 0.192" 4.877mm
7 0.176" 4.470mm
8 0.160" 4.064mm
9 0.144" 3.658mm
10 0.128" 3.251mm
11 0.116" 2.946mm
12 0.104" 2.642mm
13 0.092" 2.337mm
14 0.080" 2.032mm
15 0.072" 1.829mm
16 0.064" 1.626mm
17 0.056" 1.422mm
18 0.048" 1.219mm
19 0.040" 1.016mm
20 0.036" 0.914mm
21 0.032" 0.813mm
22 0.028" 0.711mm
23 0.024" 0.610mm
25 0.020" 0.508mm
26 0.018" 0.457mm
