Gasket Sealant? To Use Or Not To Use?
Posted 11 March 2011 - 02:29 PM
planning on replacing my head gasket.
do i need to use gasket sealant as well as new gasket or would the gasket on its own be ok?
thanks
Posted 11 March 2011 - 02:30 PM
Posted 11 March 2011 - 02:33 PM
Posted 11 March 2011 - 04:06 PM
If you are fitting a copper-faced gasket, then a slight smear of light engine oil on each side of the gasket helps with gasket seating when the head nuts are torqued down.
Posted 11 March 2011 - 04:24 PM
It's my understanding that many copper faced head gaskets have a 'varnish' on their surface which helps the sealing process. This is destroyed if you apply oil or grease.
Posted 11 March 2011 - 04:27 PM
I've never heard that and I always apply a thin smear of oil to the copper-faced ones. Have been doing so since about 1961 and never had a problem. It was something I was told by an old race mechanic from way back.
I'm not saying you are wrong, just that I never heard that.
Posted 11 March 2011 - 04:35 PM
Equally, I wouldn't say that they are all like it! It was actually a garage owner who used to do this 'years ago' who highlighted the problem with repeated quick gasket failures. He used to grease the faces. Once a new one was put on dry, it was fine.
Posted 11 March 2011 - 04:43 PM
To some this may seem like a trivial thread, but many do lightly oil the copper faced gaskets and if they are now lacquered and this nlacquer means light oil should not be used, then it's good to know. Maybe the manufacturing process changed a few years ago.
Does anyone have any more info on this as we all need to know whether to continue to lightly oil copper faced gaskets when fitting new?
I've also seen some people run a newly re-gasketed engine for around 30 seconds with no coolant in it to 'burn-in' the head gasket. It's not something I've ever done, but there are those who claim it leads to longer gasket life. Who knows? Maybe it does.
Posted 11 March 2011 - 04:54 PM
Posted 11 March 2011 - 05:15 PM
I've just checked our gasket manufacturer and they say "it is permissible to apply a light coat of oil to the metallic surfaces of the head gasket"!! So now I'm really confused! I'm trying to find the source of the 'lacquer' story.... it was quite a few years ago, but if I find it, I'll post it.
The only thing we can say for sure is that with the 'black composite gaskets (BK450) it is 'strictly forbidden' to have any grease, oil, or anything else on the gasket, block face or head face.
