Quick Battery Cable Question
Posted 12 March 2011 - 11:26 AM
cheers
Posted 12 March 2011 - 01:03 PM
8mm will be ample thickness to supply all the power needed for a mini
Posted 12 March 2011 - 01:08 PM
Posted 12 March 2011 - 01:14 PM
25mm square you mean dan? 1"ish thick cable? We used that to run 2 60hp 3 phase electric motors at the farmYou need at least 25mm, the bigger the better really. At 25mm you're only dropping half a volt due to the cable under starter load which is roughly acceptable, the resistance of the battery will be doing far worse. Down at 16mm you are dropping a volt due to the cable under the starter stall current which is starting to become significant.
Posted 12 March 2011 - 01:17 PM
Posted 12 March 2011 - 01:32 PM
Everyday is a school day as they sayCables are always sized by it's CSA, not diameter.
Posted 13 March 2011 - 05:13 PM
Posted 13 March 2011 - 07:19 PM
Posted 13 March 2011 - 07:30 PM
Posted 14 March 2011 - 09:02 AM
Posted 14 March 2011 - 06:37 PM
http://www.vehicle-w...atterycable.php
Posted 14 March 2011 - 07:04 PM
the other thing to think about is loose a couple of volts at 415v and it doesn't matter loose a couple of volts at 12v and it's a big difference
Posted 14 March 2011 - 07:39 PM
