I could now use a bit of advice for re-fitting the panel. I have a full doorstep panel from mini-spares that follows through to the rear quarter with the intention of going right through and repairing the back corner rot all in one. However when removing the old step I found the curves to be pretty good with no rot at all.
Question is do i 1. Chop the panel up and use the straight section for the step and just use the rear part of the quarter or
2. Use the whole panel and go straight through?
Secondly is it best to drill and plug weld the step on like original spot welds or seam it up?
Thanks in advance. Mark.
